CB/VHF question - Defender Source
Old July 7th, 2009, 09:46 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
CB/VHF question
I installed a VHF radio for work in the place that I had my CB. The CB was custom mounted to a plate between the sun visors. Both power and antenna cables are cut to length for that spot. Right now I have to swap radios out and antenna depending on which I need to use. What I'd like to do is mount both radios in the same spot and split the coax so both are hooked to it. Then when I need to use a radio I just swab out antenna. Anyone know of a splitter that would let me do this?
Jimmy Buffett
Old July 7th, 2009, 11:50 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Just get a coax switch that you manually flip between radios. Otherwise you'd need some sort of relay switch setup to stop yourself from destroying the other radio every time you key up.
I'd doubt radio shack would have such a thing anymore. Either a ham radio outlet or commercial communication place would probably be your best bet.
Here's a good example: http://www.universal-radio.com/catalog/switch/1636.html assuming you've got PL-259 connectors on your coax.
Old July 7th, 2009, 01:01 PM
flippedrover
Tyler
'94 D-90
That works. Thanks
Jimmy Buffett
Slider Question kellymoe Defender Technical Discussions 13 January 24th, 2006 04:52 AM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
Yet another Hardtop question sherpamike Defender Technical Discussions 2 August 15th, 2004 12:30 PM
