CB Radios - Defender Source
Old August 12th, 2005, 10:04 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
CB Radios
Where is a good place to by a cb and antenna? Also, how do I know how long of an antenna to get?
Legend in My Own Mind.
Old August 12th, 2005, 10:13 AM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Randy,
There's a place on Essex St in Lodi that sells CB stuff. All kinds of antennas, CBs, Ham Radios, custom mounting stuff. It's the strip mall next to the Hess (I think) gas station by the entrance to I80.
I use a 4' firestick on the disco and it works well. Goodluck!
Glenn
Old August 12th, 2005, 10:53 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Most truck stops have a decent selection, too. I would use the longest antenna you can fit without breaking it off in parking garages or on trees.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 12th, 2005, 11:05 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
http://www.firestik.com/Tech_Docs.htm
they have a wealth of information on their site, enough to make your head spin. They recommend that the antenna be 2' above the vehicle or clear of any object you mount it to/next to. The important part is the ground. Mounting it on a defender is tough because there are not to many good grounds. I mounted mine to my Mantec tire carrier, thinking because it was bolted to the rear cross member it was grounded. Mantec uses plastic bushing in the hinges, which kills the ground. I ended up running a separate ground wire from the antenna to the cassis. The SWR (standing wave ratio) meter reading are now on point (between 1 and 1.5), before I redid the ground the needle wanted to shoot off the meter.
As far as CB's go I use the Cobra 75 WX, it a self contained unit. It works fine and is ultra compact.
A spring stud mount is highly recommended, and a "whip" antenna is dangerous on the trail, get a tunable fiberglass one.
Old August 12th, 2005, 12:13 PM
Roadsiderob
Robert Dassler
1994 D90
Also, when buying a CB, make sure that it will hold the channel when turned off...that way you don't have to reset the CB every time you start the truck. I have had good success with Uniden CBs. Don't go cheap on the antenna. An inexpensive CB with a good antenna will outperform a good CB with a cheap antenna. I have a Wilson antenna and I really like it. It is tuned by moving a small piece in the antenna tip up and down and locking it in place with a set screw...much better than the cheap antennas that you set by trimming the wire.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 12th, 2005, 01:15 PM
Buy any CB you like, they all only put out 4 watts, it's regulated by the FCC (unless you tune it yourself to get more power ). And like Rob said get a good antenna, mount it very well also that it gets a good ground. Fire sticks are great, but a 1/4 wave legnth (102") whip will work better then just about anything except a few cases where a 7 foot firestick will work better.
Old August 12th, 2005, 02:18 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I am going to mount it on the rear tire carrier about half way up the body.. what lenght firestik?
Old August 12th, 2005, 02:21 PM
How far can it stick above the cage and not be a problem for you?
Old August 12th, 2005, 02:28 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
what do people do? 1 or 2 feet?
Old August 12th, 2005, 02:46 PM
Mine is 2 or 3 feet, but I think I am going to put a 102" whip on it as I don't have to park in any garages and I like the way they work, my 90 just came with the 2 or 3 foot Firestick. I think some of the Wilson's are collapsible if garages are the problem.
Old August 12th, 2005, 03:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
is that 2-3 feet above the roof Mike? I want to set up mine before we go wheelin again...
Old August 12th, 2005, 03:10 PM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
I've found that Bill's 2-way (www.bills2way.com) is an excellent place to get information on CB radios and his prices are very competitive. I'm about to install a Cobra 75wxst radio in my truck with a 4 foot Firestick.
I might use the antenna mount on the ARB bumper using one of the Firestick quick disconnect mounts.
Old August 12th, 2005, 03:31 PM
sheki's Avatar
sheki
David Shechter
Randy here is a shot of my 4' tire mounted firestik antenna, it's 2' over the truck's roof. It simply unscrews from the spring mounted stud, very easy to remove to get into a garage. I only have the antenna on when I'm wheeling, it's too much trouble for me to take it on and off 4 times a day. If you do run it like me, you will need to run a seperate ground (no big deal)
Old August 12th, 2005, 03:33 PM
Nope, thats 2-3 feet total, it's not above the cage really at all. It's fine when everyone is in a line and relatively close, but it doesn't seem to get very far and thats why I need to get a longer antenna.
Old August 12th, 2005, 04:12 PM
d901560's Avatar
d901560
Brian B
94 ST
I recently installed a Cobra 75wxst. It has all the CB controls on the handset which plugs into a remote box that the power leads & antenna plug into. I mounted the remote box inside the center console and ran the power wires to the stereo. My stereo has CD changer controls, so I used an adaptor to connect the external speaker output on the CB to the existing car stereo so it will be loud. I can also use the adaptor to connect the iPod. The handset bracket is mounted to the dash. The handset can be unplugged and brought inside when not in use or locked in the console. It's been too hot to wheel down here, but I'm looking forward to trying it out this fall. I still need an antenna. I'm planning to get one from a CB shop so they can tune it. I've been told that the antenna is the most important part.
Old August 12th, 2005, 06:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
does anyone have one of the cheaper $50 Uniden units or should I spring for the Cobra 75wxst ? Will that work fine with the Firestik?
Old August 12th, 2005, 07:19 PM
Roadsiderob
Robert Dassler
1994 D90
I've been running a Uniden 520XL for several years...we have them in all 3 Rovers and they work well. I orignally located my antenna on the back body by the license plate. I found the performance unsatisfactory unless I used a really long antenna to clear the roof by several feet but those kept breaking and getting hung up off road and would really beat against the rain gutter. i moved the antenna mount to the top of the A-Bar and I have much better reception with a reasonable length antenna.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old August 12th, 2005, 08:35 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
No reason why it wouldn't work.
Jimmy Buffett
Old August 13th, 2005, 12:26 AM
I have the cheapest Uniden, the 510 pro, most of the CB's out there are made by Uniden and repackaged. If you search froogle you can fiund them for around $10 +shipping.
Old August 13th, 2005, 10:32 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Radioshack (and others) sell SWR Meters that you use to adjust your antenae length. Personally, I run the KB antenae which I feel is one of the best on the market and has an adjustable tip (an allen screw loosens and you can extend the tip or retract it to get the best meter reading). This is the best way to have a great CB. Antenaes and CB's be damned, the real deal is in the tuning.
radio
CB Antenna Mounting nycjdp Defender Technical Discussions 36 March 6th, 2010 07:35 PM
Won't Start After CB Install floyd650 Defender Technical Discussions 7 December 8th, 2008 06:18 PM
Iron Goat Dash with CB Bozman Smaller Projects 16 July 31st, 2008 08:30 AM
Satellite Radios and Recievers? boshea Misc. Chit-Chat 15 July 16th, 2006 10:06 PM
Cb Radios ronward Misc. Chit-Chat 0 August 9th, 2004 09:53 PM
» Defender Registry
Hazel
BullTrout14
D90
NPT90
Add your Defender
