Caution, VW question... - Defender Source
Old April 20th, 2015, 01:00 PM
Grover's Avatar
Grover
My wife's 2010 Jetta tdi gives an esclamation point message in the lower left hand corner of the center display when moving more than 4mph. What is this? I have called several dealerships and they have no clue...
It's not the brake nor tire pressure warning...
...I love the simple ness of my Defender...
Old April 20th, 2015, 01:07 PM
Grover's Avatar
Grover
Question Caution, VW question...
Old April 20th, 2015, 01:10 PM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
Try posting on VW Vortex you will get a reply in an instant.
Old April 20th, 2015, 01:11 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Ditto! I love not driving around a computer. With regard to your issue, does your cruise control work? I found this on the tdi forum.
"A very common problem with modern Dubs is the brake light switch. There are 2 contacts in the switch. One for the CC and one for the brake lights. If your CC doesn't engage, I would go there first."
"had this happen to mine every time I used the right turn signal. then after a while it was just "!" anytime the car was moving. VCDS showed an error in my turn signal stalk. tried taking it apart and cleaning cc switch but no help. I changed the turn signal stalk and no problems since. Job was not too difficult, took a couple hours."
Old April 20th, 2015, 01:45 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Originally Posted by Grover View Post
My wife's 2010 Jetta tdi gives an esclamation point message in the lower left hand corner of the center display when moving more than 4mph. What is this? I have called several dealerships and they have no clue... It's not the brake nor tire pressure warning... ...I love the simple ness of my Defender...
might be the tire pressure light as well
cruise control issue ...
Old April 20th, 2015, 01:53 PM
merged the threads ...
Old April 20th, 2015, 03:18 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Does she have her seatbelt on? My new WRX does the same thing if you do not have it on.
NAS AC wiring question or call it a random wire question bjf Defender Technical Discussions 7 May 5th, 2009 09:58 AM
Caution Potential Scam jax Misc. Chit-Chat 14 October 30th, 2006 04:29 PM
ARB Bumper 97 Transmission Cooler Caution dnewman9 Defender Technical Discussions 4 September 8th, 2004 12:51 AM
