Can a 200tdi be imported? - Defender Source
Old August 28th, 2011, 02:55 PM
JBinAlabama
john
Series 2A ..more parts on the way
and who should I contact?
The prices in the US seem pretty high
It's for an old series.
Old August 28th, 2011, 03:31 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
I brought one in last Nov, so it can be done, talk to Doug C.
Old August 28th, 2011, 08:05 PM
rovertrader's Avatar
rovertrader
Dale
I have a complete 200 set up, still in the donor and can be driven prior to purchase. Not crazy money but no give away either, depends on what all is wanted for pricing...
Old August 29th, 2011, 06:08 AM
globallandrovers's Avatar
globallandrovers
Julian Kotting
1999 P38 DT, 1997 LHD 110 CSW
Location: Hertford UK, Wilmington, NC, Austin, TX and OH
The answer is yes you can bring in an engine, do not label it as a 200tdi, just as a replacement diesel engine.
Land Rover Defender Specialist. - We ship worldwide.
We are a specialist in TDI re-power conversions, and Crate 'turn key' Land Rover TDI and TD5 engines and Transmissions.
Old August 29th, 2011, 01:47 PM
johan's Avatar
johan
johan
2009 Range Rover
I have had big problems with this. If you find the right customs agent I am sure it is possible but if you are so unlucky you get the same customs agent I had, it might give you a headache.
An engine should be brought in with a HS-7 form, the same to import a car. On this form it gives the 25 year EPA exemption rule for cars. For just engines though, there is no excemption rule mentioned on this form. It clearly says all engines have to meet EPA.
After a month at customs they released it because they finally beleved me (or they didnot beleve me but were sick of me calling everyday ) it was an original replacement engine for my 1981 Land Rover. I had to prove though that this car was mine by giving them a copy of the title.
If you do it, try to find someone who can give you an invoice and have them print a producion date of at least 25 years ago, on it. This might make it a little bit easier.
Johan
Old August 29th, 2011, 05:07 PM
kjva
Ken Jackson
1985 110 Wagon
Defender 200 tdi engines still go for around 1000 UKP, an exchange fuel pump is around 700 UKP and a set of injectors around 300 UKP. In theory they should be allowed in under the 21 year ancient engine rule shortly.
200tdi, import, tdi
Adding A/C to a 200tdi Defender dave_lucas Defender Technical Discussions 35 October 3rd, 2015 03:41 AM
Disco and the 200tdi swap Stork17 Defender Technical Discussions 13 December 1st, 2008 08:30 PM
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
200tdi D110 Camel Trophy 65k Eric Siepmann Misc. Chit-Chat 22 May 26th, 2005 05:16 PM
