Camel 110 #Africa - Page 6 - Defender Source
Old October 23rd, 2014, 02:40 PM
Mtanzania
Frank
1994 D1 300tdi - Sold :-(
Originally Posted by RX6RCROL View Post
Lake Malawi.
Attachment 90507
Those of us from Tanzania like to call that "Lake Nyasa"....course, we have lake Tanganyka and Lake Victoria, so I guess we should let them call it Malawi...
94 D1 300tdi - Sold
93 LWB-Isuzu diesel 5 speed
Old October 24th, 2014, 03:40 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Drove 975k's today.
Trucks making a clunking sound just as it rolls to a stop, gearbox in neutral, clutch out. Sounds like e-brake sticking, maybe the rear end. Anybody recognize the symptoms?
Old October 24th, 2014, 03:44 PM
does the ebrake work?
Mark Kellgren
KM4BOR
Old October 24th, 2014, 03:48 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
This happened yesterday. New rear fuel tank but, sending unit was put in incorrectly and the tank wasn't filled after the install. Easy fix, massive headache. Custom's officers were escorting me to the border when I stopped to fuel up and this went down. Lucky for me they enjoyed being out of the office and were in no rush to get back.
Old October 24th, 2014, 03:52 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Barely works.
Old October 24th, 2014, 03:55 PM
clunking may be the ebrake disc pads worn down causing play between the now slack space between the drum and expander. quck turn of the 1/2" adjuster should fix that in a jiffy
Mark Kellgren
KM4BOR
Old October 24th, 2014, 04:04 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Thanks! That makes sense. Tomorrow I'm headed to Kruger and I'll have a few days to wrench and relax while I wait for my buddy who's flying in for the trek to Cape Town.
Old October 24th, 2014, 04:58 PM
the rover shop
shayne young
If you pull on the brake slowly as you come to a stop it should change the noise if it is the brake..
Old October 24th, 2014, 05:40 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
Clunking sound may come from the A-frame ball joint. Have a look at the grummet. If it's worn, the grease inside might be replaced by mud.
Old October 24th, 2014, 07:39 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Joints new. I'll check and make sure everything's tight.
To me the noise sounds like rear diff gears slapping, maybe caused by something in the e-brake catching then letting loose, or something in the diff catching. When it's knocking, it's loud enough that I wonder if somethings going to completely lock up the next time it knocks. Keep in mind, putting the gearbox in first, clutch out, idling at the same slow speed equals zero knocking. And when rolling there's no knock until the trucks going forward under 1mph. The knock can easily be avoided at intersections by slowing down very quickly from 3mph to zero.
Old October 24th, 2014, 08:05 PM
if you want to rule the ebrake in or out, take your 1/2 open end, go under and completely loosen the adjust bolt a few turns on the back of the ebrake (counterclockwise). that will clearly seperate the pads from the drum. Then drive it (no ebrake FYI) and see if the noise is gone.
Mark Kellgren
KM4BOR
Old October 25th, 2014, 12:37 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
On the door steps of Kruger.
Old October 26th, 2014, 05:08 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Kruger. This place is very cool.
Old October 27th, 2014, 09:44 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
The problem was...rear half shafts. The splines are so worn that it's remarkable they hadn't spun inside the hubs yet. Both axles are being rebuilt now, should be done by tomorrow at 5...how so fast???? Well, the guy working on my truck, Vernon, his claim to Land Rover fame...when he worked for Land Rover between 1992 and 1996, he built camel trophy trucks! Click image for larger version
Old October 27th, 2014, 10:00 AM
the rover shop
shayne young
That's cool. Will be like a blast from the past for him..if you need any parts Matt, I know I've said it before... But I'll say it again.. Just let me know and I'll ship em to you as fast as possible.. Although I'm sure parts for landies aren't scarce in Africa. My wife and I just did a couple of events over here and we have itchy feet to get back on the road..hoping that we may coordinate a couple of weeks with you guys there in our camels... That would be kinda cool...I may even be able to get a couple of friends to drive my other 2 as well..4 camels trekking across Africa... Uber cool..
Old October 27th, 2014, 10:20 AM
belgian's Avatar
belgian
Maxim
1995 RRC SWB
The moment I retire... and I put a 200tdi in my Camel.. I'm on that list. 5 camels.
1984 Camel Trophy 110
1995 Range Rover Classic SWB
1992 Range Rover Classic SWB
Old October 27th, 2014, 11:13 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
When Hinckley changed Rivky's haulout date Rebecca told me to keep my trip to Africa as planned, she would handle everything. Love that girl.
Old October 27th, 2014, 11:16 AM
the rover shop
shayne young
Isn't it great to have a good woman like that... I struck gold with mine.. Sounds like you did too..
Old October 27th, 2014, 11:20 AM
Stone Accessories's Avatar
Stone Accessories
Deborah and John Barry
1996/Defender 110
What a great story! I just read through all of it.
If you're able, make a stop in Betty's Bay (about an hour and a half from Cape Town) to check out the penguins!
Debbie
Website:
Contact:
Join us on Facebook:
Old October 28th, 2014, 04:47 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
NAS 110 Rear Bumper Reefminis Wanted 3 October 2nd, 2006 04:54 PM
1986 Land Rover 110 Soft-Top Tdi Lurker For Sale - Vehicles 3 June 7th, 2006 11:03 AM
Importing a 110 to the States mfreeman17 Misc. Chit-Chat 18 April 14th, 2005 02:02 PM
110 Rock Sliders tobit3 For Sale - Parts 4 March 24th, 2005 05:17 PM
110 Military Swivels, balls, CV's, complete outer Buckon37s For Sale - Parts 20 November 3rd, 2004 12:14 PM
