bumpstops - Defender Source
Old September 30th, 2003, 07:29 PM
DBZ2009's Avatar
DBZ2009
Z
ex-1994 D90/ 2 j**ps
bumpstops
what size bumpstops should go with a 3 in. lift and long travel shocks? Anyone know where I could get some cheaply?
THANKS!
Old September 30th, 2003, 07:38 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
4" pump stops. You can buy some from summit racing but you have to build brackets for them to fit. NSO and SG sells bump stops too.
World traveler
Old September 30th, 2003, 11:26 PM
redrover
Guest
Posts: n/a
bumps
I have a sg stage3 and external fr shocks. it would be very easy to either weld a spacer between old mount and use longer installation screws, or just tack weld a boxed steel spacer onto platform where bumpstops bottom out on axle.
remember the dist under stops should be smaller than remaining compression dist on shock when truck is level. But also remember that when the suspension is cycled through max articulation, the origional bumpstop may now be to short thus allowing shock to bottom--so it may take some trial and error.
Old October 2nd, 2003, 10:32 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
Yeah the boxed spacer is another way to go; in fact Matt @ Rock Ware has his like that
World traveler
« moab | thanks folks »
1985 L/R 90 2.5 petrol into something Mo better tomaco1 Truck Build-up's & Restores 203 January 16th, 2013 02:36 PM
Another suspension question Joe P Defender Technical Discussions 1 March 15th, 2005 02:30 PM
Sliding down the slippery suspension slope souza Defender Technical Discussions 18 February 3rd, 2005 11:06 PM
4 Safari Gard Bumpstops Buckon37s For Sale - Parts 1 March 24th, 2004 01:44 PM
New Rover 9in almost ready Buckon37s Misc. Chit-Chat 55 November 12th, 2003 02:53 PM
