Bulkheads rust proofing measures... - Defender Source
Old January 27th, 2010, 09:06 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
Ok In my near obsessive level of reading lately, along with talking to others I have discovered that there is a LARGE danger in galvanizing the bulkhead. Apparently it is a serious roll of the dice to galvanize one and have it come out straight...
A frame is apparently straight forward but the bulkhead can warp. It was suggested to build a metal frame around it for the dipping to help but even that is not a guarantee.
Soooo I was wondering, once assembled how much rubbing against the rest of the body occurs during driving? The reason I ask is I am wondering about powder coating AND I have yet another idea.
There is a product called gunkote.
https://www.kgcoatings.com/index.php...ewCat&catId=28
It is a Spray on bake on coating originally designed to coat the inside of oil pipe lines and then adapted to firearms. It is a Moly coating that is litterely baked (300 degrees for 1 Hour) into the surface of the parent metal. On firearms once you apply it the only way to get it off is sandblast. My thought here is to use the gunkote as a primer and first line corrosion barrier. A powder coating facility could apply it and bake it, then go over it again with powder coating.
So what does anyone think of that as a possible alternative to galvanizing the bulkhead?
IPSC_GUY
SIERRA II ALPHA
Old January 27th, 2010, 10:02 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I have galvanized tow of them to now with both minimal warping. The only thing to remember is to have the properly repaired and prepped before.
Once it is done you will require some force to put the two long bolts that hold the bottom of the bulkhead to the frame. Both of mine were off by 1/4 to 1/2 inch and just had a couple of guys to pull on it to get the holes aligned properly.
I would not hesitate to do it again if I had to. Once galvanized you are done for a very very very long long long time !
My .02$
Pat
Kirk Lazarus, Tropic Thunder
roof
waxoyl Rust Proofing Service whtd90 Misc. Chit-Chat 0 January 21st, 2009 04:01 PM
Rust in the door handles??? adibitar Defender Technical Discussions 4 October 10th, 2004 10:01 AM
Rust? mlw911 Defender Technical Discussions 6 May 24th, 2004 03:48 PM
