broken throttle cable - Defender Source
Old November 24th, 2008, 09:23 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
what should I pay to have this repaired?
Old November 24th, 2008, 10:35 AM
not much. its easier than installing an air filter.
Old November 24th, 2008, 01:07 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Is 100 bucks too much?
Old November 24th, 2008, 01:11 PM
mattdh's Avatar
mattdh
Matt Hurst
jims right. its super easy. i think its just two pins (one on each end)
Old November 24th, 2008, 01:46 PM
If someone else does it, you're probably going to be billed for at least an hour of labor, and of course the part. If you get out for under a hundred, that would be good.
You can of course do it yourself for the cost of the part.
Old November 24th, 2008, 01:55 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
Ok... anyone in colorado have a throttle cable I can buy from them? Flatirons is the closest one to me and they have to get it in and it won't be until tomorrow.
Old November 25th, 2008, 01:50 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
Philip, If you get the part I would be happy to help you put it on, but you may need to drive to fort collins with a stick shoved into the butterfly, wait is that not rover cruse control.
Old November 25th, 2008, 10:47 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
ha! Thank you so much for the offer, I am going to try to do it myself, and if that fails, I might certainly take you up on your offer!
Old November 25th, 2008, 08:54 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
WOW that was really easy. Couldn't get the rubber gasket all the way into the hole in the cab. Any tricks to getting that all the way in? I don't want to use WD40 as I think it is corrosive to rubber.
Old November 25th, 2008, 09:18 PM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
I sometimes use a hair dryer to do things like that.
Old November 25th, 2008, 10:30 PM
Dish washing soap. I dont think you have much to fear from the WD40 on the rubber.
Broken Defrost Diverter Cable? Wolf Fabrication Defender Technical Discussions 4 June 26th, 2008 04:15 PM
Help installing choke/hand throttle cable KevinNY Defender Technical Discussions 12 February 12th, 2007 10:45 AM
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
