Bridging Ladders - Defender Source
Old November 26th, 2012, 10:24 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Bridging Ladders
Ok so itís not often that I like someoneís work so much that I buy multiples of their product, but I have to tell you about a guy I met in MOAB. His name is Casey and he does fab work. He's the same guy I let wheel my truck a bit in MOAB.
Anyway he makes bridging ladders among other things. 4, 6, and 8 foot, the cool thing is a set can be locked together to for a pedestrian bridge or they be hinged together to traverse a log. Made from Aluminum...very strong. The pedestrian bridge can support 400 lbs. When I get mine in I'll post some more photos, the set posted here is one of the first sets he messed around with.
The photo posted is just a regular set, no locks or anything.
Website; www.caseyscustom.com
Email; Caseys Rover customrover@gmail.com
I have on order four sets so there ya go.....
Old November 26th, 2012, 10:59 PM
bossman429's Avatar
bossman429
Adrian
1988 90
Looks like atv ramps to me
Old November 27th, 2012, 05:25 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Except stronger.
Semper Fi!
Old November 27th, 2012, 07:33 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
For how many dollars?
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old November 27th, 2012, 09:07 AM
Bill Larson
Bill Larson
The 4' ladders, hinged and lockable cost me $200.00 a set.
Old November 27th, 2012, 09:59 AM
Weight?
Old November 27th, 2012, 10:02 AM
Bill Larson
Bill Larson
Originally Posted by Rocky View Post
Weight?
Dont know....you'll have to contact him on the specs. Sorry.
Old November 27th, 2012, 10:29 AM
more importantly, capacity weight? I've looked at ATV ramps, but the strongest ones are only good for about 1-1.5k lbs. not strong enough for a fat 110.
Mark Kellgren
KM4BOR
Old November 27th, 2012, 10:37 AM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Have you considered these?
http://www.okoffroad.com/gifs/stuff/waffleboard-4.jpg
That's Adrian's DI and they barely budge.
John C.
Old November 27th, 2012, 11:03 AM
Bill Larson
Bill Larson
I'll ping him today and get his specs.
Old November 27th, 2012, 11:12 AM
JohnC
Actually those ladders are ours, I think we have a few more sets left.
John C.
Old December 12th, 2012, 11:17 AM
Bill Larson
Bill Larson
ok so I have an update on these.
Typical Configuration; 4í Bridging Ladders
Each 4 foot long, 14 inch wide, section weighs 20 lbs. and can support 1,800 lbs. per section over a 4 foot or less span. When spanning a four foot or less area, using both sections the bridging ladders will support 3600 lbs. When joined and locked together the 2 four foot pieces fitted and locked can support 500 lbs. over 8í span forming a bridge to move equipment.
They are 3 inches tall 14 inches wide and 4 feet long weight 20 lbs.
ID:	62639   Click image for larger version
ID:	62641   Click image for larger version
ID:	62643   Click image for larger version
Old December 14th, 2012, 07:02 AM
bossman429's Avatar
bossman429
Adrian
1988 90
Typical Configuration; 4’ Bridging Ladders
Each 4 foot long, 14 inch wide, section weighs 20 lbs. and can support 1,800 lbs. per section over a 4 foot or less span. When spanning a four foot or less area, using both sections the bridging ladders will support 3600 lbs. When joined and locked together the 2 four foot pieces fitted and locked can support 500 lbs. over 8’ span forming a bridge to move equipment.
So basically atv ramps after all? 1800lbs is barely 1 axle with a loaded rig. And 500lbs is nothing. You'd be just as well off with a 2x4.
I have a set of aluminum ramps for my trailer that are 5' long, weigh maybe 20lbs each, and support 3000lbs per axle. If your set on carrying something to act as a bridge, get a set if those. Also the ladder like design would prob make them useful as sand ladders. I think I got them from discountsramps.com
Old December 14th, 2012, 07:23 AM
Wolf Fabrication
Sterling Archer
'08 D3
Its not 1800lbs per axle, it's per corner. You are only going to have one tire on a ramp at a time. Use two to cross a gap and its 3600lbs per axle.
Semper Fi!
Old December 14th, 2012, 07:44 AM
bossman429's Avatar
bossman429
Adrian
1988 90
OK - i did misread a little (thats what i get for looking at d-90 while still in bed).
However, thats at 4' anything over 4' it sounds like you significantly reduce its capacity, which i thought the whole point of these things was to be able to expand.
You certainly could not cross a 8' span
So they are much better than i first thought, but im still not sold on the idea.
Old December 14th, 2012, 08:23 AM
Bill Larson
Bill Larson
Wolf is correct thats per axle. he makes them up to 8' I believe. For me, I thought 4' was better than nothing. I'm going to try them out anyway...my first set arrives next week and I want to take them wheelin in January. A friend of mine has an FJ and and were going to see if we can break'em.
Also when connected togeather it's for moving equipment. If that Eq. is on my back well than that the chance I take but thats what it's for. 8' span, min 500 lbs. I would think one person at a time would not exceed that.
There has been a price increase for me because of these modifications/improvements, but the good thing is he's not expensive to start anyhow. I'll report back anyhow with photos and the like next month. Oh and zombies cant traverse open air! and Rovers cant either without bridging ladders!
Old December 14th, 2012, 08:26 AM
Wolf Fabrication
Sterling Archer
'08 D3
If you have to cross anything larger than a 4' gap, then you are going Camel Trophy style and cutting down trees to build a bridge. I'd go with a 5' section and beef them up a tad.
Semper Fi!
Safety Devices NAS 90 roof rack rear ladders and parts ECR The Vendors Loft 3 March 1st, 2010 08:29 AM
Roof Rack and Ladders m.michaels Wanted 0 February 10th, 2006 12:44 PM
WTB: Full Safari Roof Rack and Ladders maxwell Wanted 0 February 8th, 2006 11:31 AM
Sand ladders Rover- Girl Defender Technical Discussions 9 June 28th, 2005 12:39 AM
Aluminum Mud/Sand Ladders C-Delta For Sale - Parts 5 July 12th, 2004 11:02 PM
