Brandon Tinders Across America aka. MURICAH and a little bit of CANADUH - Page 7 - Defender Source
Old October 21st, 2015, 10:33 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
From what he described it sounds like he broke the layshaft(maybe mainshaft, could be confusing them).
Doug has a iia tranny that might be an option.
Jumping it off a cliff and buying a Toyota is also an option
Old October 21st, 2015, 10:52 PM
Let me know and I'll ask the customer, its just taking up space here.
Changing a series gearbox is a pita.
Old October 22nd, 2015, 12:46 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Originally Posted by rwollschlager View Post
If anyone knows of a known-good series transmission between Bentonville, AR and Omaha, NE let me know.
Pendy is between Bentonville and Omaha, but he hasn't been active on the board for awhile that I've seen.
Old October 22nd, 2015, 09:24 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
He wants an S3 box. I think he doesnt want to pull the current box apart, as it still works, and you risk it not working when pulling it apart. Plus we were trying to get something to Omaha first, this way Rob could order parts and fix it before the Air Portable gets there.
Old October 22nd, 2015, 10:09 AM
smithco1
Tim Smith
74 Lightweight
I've pretty much exhausted my list of possible tranny whisperers (did I say that?) on my call down list here in the NE and no one has a SIII box ready to go right now. I do have a SII box that he could have for a while but it has a chipped 1st gear and of course he'd have to re-route the clutch slave. Probably not the best option.
The problem he's having sounds very much like the main shaft just loosened up on him and the distance piece between 2 and 3 has worn it's self down which is making 2 and 3 iffy at best. He should be ok limping it home on that box if he avoids using those two gears. "Should"
This truck probably hasn't seen this much highway usage since... ever. The poor thing is obviously trying to burn through the arthritis pains and good ole' Brandon isn't taking no for an answer. Brandon is my hero right now.
Old October 22nd, 2015, 10:49 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Anyone reach out to the Canadians?
Old October 22nd, 2015, 10:55 AM
When he was at SW Rovers, they found a broken "circlip" on the drain plug. They were pretty sure it was the mainshaft spring ring, RTC1957. With this gone, 2nd and 3rd have axial float on the mainshaft making engaging them difficult.
Old October 22nd, 2015, 11:18 AM
airbornrover
William Skidmore
SIII 109 SW
Yes those people.
Canadians? The mythical people that come from the supposed land above Montana? I've heard it spoken of, but it's not on any maps.
-Jeff
Old October 22nd, 2015, 11:43 AM
JohnsD90's Avatar
JohnsD90
-Jeff
The western atlantic?
Old October 22nd, 2015, 12:04 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Sounds like Jonesy's twin.
Old October 22nd, 2015, 12:34 PM
FWIW, SIII bellhousing will fit on a post-suffix something or other IIa box and vice versa. As long as it has the large layshaft front bearing. So the slave cylinder issue shouldn't be a factor if you find a good later IIa box
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old October 22nd, 2015, 12:35 PM
smithco1
Tim Smith
74 Lightweight
I hope you didn't think my post was a slight toward you or the truck. Believe me, I've had these sorts of issues with my own lightweight at one time or another. These are old cranky bastards and putting them on the highway for extended periods with someone who drives with as much gusto as Brandon is surely going to find the low hanging fruit sooner or later.
I'm just trying to help out with whatever little pieces of info I can. I may not have much but at least I have a tranny call down list. Did I just say that again?
Old October 22nd, 2015, 12:54 PM
Not at all. Just trying to help out by clarifying what is the problem as far as we know. If there is someone friendly on his route, that is not scared of gearbox internals and does not charge for their work.... they could fix it up. Probably just need this $2 part and a bunch of labour. Brandon is not scared of fixing things.
Especially, as it seems, finding good known Series gearboxes lying around loose is not a simple task these days.
I'm sure he is fine though. The engine pulls like a train down low. You can happily run in fourth at 25 mph. With the overdrive, he really still has 4 gears...
Old October 22nd, 2015, 01:12 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
There's one here in Maine on CL.... Land Rover series 3 transmission
Old October 22nd, 2015, 01:15 PM
JohnsD90's Avatar
JohnsD90
He just talked to him, I think this is going to be the replacement box!
Old October 22nd, 2015, 01:18 PM
Kevin88RRC's Avatar
Kevin88RRC
Kevin Keith
1988 RRC
Buxton is not too far from me if there's any help needed.
Old October 22nd, 2015, 01:26 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Matt is on here too, probably not drawn to this thread based on selling a gearbox
Old October 22nd, 2015, 01:42 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
No he does not have the tool ..its his first series
No Mall crawler here
Old October 22nd, 2015, 02:04 PM
with an OD that nut requires 100ft lbs so it is best to use the tool. Don't think there is a factory spec for the mainshaft nut when used without an od. Just "tight"
Present:
1987 RRC- "Chewy 2"
Past:
Old October 22nd, 2015, 02:05 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Does Brandon have the special main shaft tool? Does he need the stock Tcase gear in case the OD shits the bed? I can mail both out if needed.
-Jeff
Why do you have that...none of yours are running!
ac
Little bit of heritage flippedrover Misc. Chit-Chat 6 September 12th, 2015 02:24 PM
Little bit of Racing history. flippedrover Misc. Chit-Chat 0 April 2nd, 2015 12:44 PM
Hmm, maybe a little bit . . . Filmtwit The Flea Market 4 October 3rd, 2014 11:52 AM
John Gadd aka Rover Dude aka Union Jack 4x4 hankhowi Misc. Chit-Chat 20 July 26th, 2013 04:16 PM
Ordering parts and accessories from across the pond shawnpalmer Misc. Chit-Chat 6 October 18th, 2006 04:56 PM
