Brake rotor wear ... - Defender Source
Old February 23rd, 2015, 03:28 PM
Does this look normal?
Can this be turned?
Old February 23rd, 2015, 03:36 PM
ezzzzzzz
Mark Garrenton
I seen the same on other vehicles including an old '78 Ford van that had been inspected recently! I've also seen the rear brake pad drop and eat a slot through the rotor top hat of many LRs.
Old February 23rd, 2015, 06:19 PM
Can this be turned?
Looks about like yours!
Old February 23rd, 2015, 06:36 PM
the rover shop
shayne young
That's normal..that's the new slotted brake rotors..
Old February 23rd, 2015, 07:21 PM
Mine had corroded so badly they weren't wearing down any more ...
Old February 23rd, 2015, 09:06 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I had a ROW 110 in that had so many sets of pads put on it that it had worn the solid front rotors to less than 8mm thick. Also had a customer let his son replace his pads and the car came in with a grinding sound because the friction side of one of the pads was against the caliper....
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 24th, 2015, 12:14 AM
Lol.
brake
Need Distributor Help - Rotor and Rotor Arm Questions rijosho Defender Technical Discussions 16 September 16th, 2013 09:56 PM
Brake/Friction Pad (and maybe Brake Disc/Rotor) Replacement rijosho Defender Technical Discussions 62 March 16th, 2011 03:55 PM
Brake pad wear? Hammertime Defender Technical Discussions 1 March 15th, 2010 09:26 PM
output shaft spline wear ZACHASS Defender Technical Discussions 8 February 3rd, 2009 04:01 PM
Brake Rotor wear Eric Siepmann Defender Technical Discussions 1 October 1st, 2004 11:42 AM
