Bottom line on chassis brands - Defender Source
Old December 31st, 2014, 01:04 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
I've done some research here and I'm still undecided about a galvanized chassis. Some offer theirs with threads chased after dipping, finished edges, etc. And, other brands don't even mention this leading one to believe that it could be rougher upon receipt.
So what brand chassis or source do you guys recommend for a NAS 90?
Old December 31st, 2014, 01:20 PM
I did an entire frame off on a stock chassis that was galvanized. I'm not sure what qualifies as "finished edges" but there were certainly no threads in the chassis anywhere that needed to be chased.
Are there actually threads on a NAS chassis?
From what I've read, you should really be most concerned about dimensional accuracy and metal thickness. Some chassis are more accurate and/or stronger than others.
Old December 31st, 2014, 01:33 PM
rankar's Avatar
rankar
Good points. I assumed if you're in the business of selling a chassis that it would be dimensionally correct.
I've got two soft spots on my chassis, so I figured just get a new one.
But is it legit to cut out the soft spots, weld in new pieces then galvanize? I'd love to keep the original chassis...
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I did a build with a brand new Marsland chassis and was very happy with the quality. All threaded areas were re-tapped after galvanizing (i.e. bumper mounts under rear cross member, etc)
Old December 31st, 2014, 01:36 PM
No a simple thing with a Land Rover as dimensional accuracy from the factory is plus or minus an inch.
Old December 31st, 2014, 01:42 PM
rankar's Avatar
rankar
Holy crap!
Old December 31st, 2014, 02:04 PM
Yes, and even preferred since you have the original vin stampings.
Originally Posted by pendy
I'm here for the D's
Old December 31st, 2014, 02:18 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Same here. If any of the distributors offered them with thicker main rails, that would be a plus in my mind, however, I am very pleased with my Marsland chassis.
1970 SIIA 88, Sold
Old December 31st, 2014, 02:30 PM
Designa used to offer that option.
Old December 31st, 2014, 02:46 PM
rankar's Avatar
rankar
Thanks guys. Great idea about the beefier main rails, that's definitely something to consider doing to my oem chassis.
Old December 31st, 2014, 03:19 PM
jwb
Jason
1988 110 CSW
If interested in beefier rails then you might consider Richards Chassis, they use 2.5mm steel vs 2.0 mm on OEM/Marsland. Richards can also make with 3mm rear crossmember.
Old January 1st, 2015, 06:10 AM
another thing is the rear tub brackets. some chassis have the option of a two-piece tub bracket, vs earlier chassis in which the tub supports were welded onto the rear crossmember.
my truck has the earlier welded construction and it is a pain compared to the two piece type. the two piece type also allows you to adjust the door gaps much more precisely, which is arguably one of the few places where tolerances actually seem to matter on the truck
Old January 1st, 2015, 08:05 AM
Can't recall who made my galvy chassis that I got from ABP.
If you take your OEM, repair it, Duncan in Everett Mass has done chassis in the past. They can even colorgalve it.
Old January 1st, 2015, 09:17 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
If you keep the original chassis just make sure you document the repairs and use a professional if you're not doing the work. After it's done depending on your level of teardown, use a rust neutralizer and inhibitor in the frame. Then Waxhol the heck out of it...look forward to your updates. Good Luck!!
Old January 2nd, 2015, 11:17 AM
This is what I'm talking about (TD5 rear crossmember)
http://www.marsland-chassis.co.uk/td...ossmember.html
Old January 2nd, 2015, 01:40 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Dave at urban stocks RC usually
Old January 2nd, 2015, 05:36 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
AB had a sweet sale on RCs last month
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old January 3rd, 2015, 07:19 AM
rankar's Avatar
rankar
Thanks guys, obviously a lot more to research and consider.
------ Follow up post added January 3rd, 2015 07:21 AM ------
Bill, would you still recommend galvanizing the original chassis after repairs? Or did you mean something else when you recommended rust inhibitor?
Old January 3rd, 2015, 03:51 PM
Personally, I would much rather have an original chassis that has been galvanised. The problem is that you might not be able to tell how bad it actually is until it is blasted. The metal could be very thin and it might be past the point of being worth repairing.
Old January 3rd, 2015, 04:18 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Brewie212 is building my 110 on a Richards Chassis I ordered through Randy Kremer. When I saw it before it shipped down, the quality was impressive and all the threads looked to be clean and ready for installation.
Water Pump Brands petminded Defender Technical Discussions 4 May 9th, 2014 02:17 AM
What adds more value: early original chassis or galvanized chassis? nathanwind Misc. Chit-Chat 25 December 7th, 2012 09:49 AM
Front brake line - why hard line & flex line? jefhuf Defender Technical Discussions 5 January 13th, 2012 09:03 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
removing weather stripping from door bottom JRowe Defender Technical Discussions 4 November 6th, 2003 01:53 PM
