Booger welding - Defender Source
Old March 23rd, 2010, 07:38 AM
Booger welding
I was doing a little bit of welding on the Bandit Chipper yesterday. Some time in its history the fender that the hydraulic tank sits on go whacked and it caused the thin metal to tear with the weight of the tank rattling away year after year. Anyway, I tried to stitch the crack back together with my flux welder. I eventually got it but only after burning through in several places and generally making one of the ugliest fixes I've ever seen.
Does anyone have any suggestions as to how one would butt weld thin stuff like this ? I tried several wire speeds and both hi and low settings without any discernible improvement in the weld. The fact that my welding skills are terribly bad and that the fender was in a somewhat odd position didn't help. I just ground off the big globs and painted it, since the overall look of the contraption is not too purty.
Old March 23rd, 2010, 07:51 AM
I'm hardly an expert but I would say use low heat,, small diameter wire, and low wire speed as well. Hold the torch a bit furter from the ork and or angle it down to reduce penetration if need be. Stitch it together with short welds so as to keep from overheating the work. Gas would help alot too.
Old March 23rd, 2010, 08:25 AM
What he said. Position helps a lot too. How thick are we talking btw?
Old March 23rd, 2010, 08:38 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
All of the above and make sure the area is super clean. Are you able to get some material behing the weld area? I will sometimes use a huge bolt, and hold the head behind the weld to act as a "floor" for the weld.
Either way, butt welding sheet metal is one of the hardest welds to master, so don't feel bad. A professional restorer would be use a gas-shielded MIG or even better, a TIG, so don't feel bad.
Semper Fi!
Old March 23rd, 2010, 02:56 PM
Run a series of spot welds across the whole thing. Start with one in the center and then one in the center of each side and keep working your way side to side until the whole thing is filled with spot welds. Then touch up any areas that leak with more spot welds.
Old March 23rd, 2010, 04:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
You can't do it with flux. You need gas. Even then it can be a real pain.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 23rd, 2010, 04:21 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Also start the weld slightly away from the seam and work in toward the seam in a small circular motion. If you try and start the arc right on the seam it will blast right through.
Old March 23rd, 2010, 04:48 PM
Maybe I just suck, but I have done this with my little hobart flux thing and it worked fine.
Old March 23rd, 2010, 06:11 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
If you have a really good machine I think it might be possible. But flux burns hotter than gas and is much harder to work with on thin steel.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 23rd, 2010, 06:13 PM
C, the fender is really thin like maybe 16g or sumthin. About 2mm at most. Welding thru rust didn't help. Doing it at 10:30 at night didn't help. I actually was using ron's spot weld technique...add a dollop of metal and beat on it, add a dollop and beat on it some more...eventually it more or less happened. I guess I got a little greedy and held the tip in place too long. Hafta practice Dave's penetration reduction techniques. Still really ugly. Goes with the chipper's aesthetic tho.
All to a good end. Took down the big magnolia in my front yard today. Chipper happy, chainsaw happy, Bill happy.
Anyone need some magnolia flavored mulch?
Welding thin aluminum air condintioning tubing? Davis Defender Technical Discussions 5 January 9th, 2010 06:38 PM
Welding equipment paul64 Defender Technical Discussions 28 July 20th, 2009 02:55 PM
welding diff guards rover4x4 Defender Technical Discussions 6 March 26th, 2006 03:50 PM
QT Services Diff Guards and HD Engine Mounts JohnC The Vendors Loft 1 February 16th, 2006 09:53 PM
Group Buy-ReadyWelders 10% Over Cost RedRhinoProducts The Vendors Loft 0 January 27th, 2005 09:07 PM
