Bonnet mounted Spare - Defender Source
Old April 10th, 2008, 03:56 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
I saw the kit for sale in the FS section and it got me thinking about doing this. I did a search and have seen the pros and cons, but I love that classic LR look. I still have the steel spare from my old '95 Disco. Thinking about putting a smaller tire on it and doing a bonnet mount. Thoughts? Any pics 90s with this mod would be appreciated to help me decide. BTW I would keep my rear spare, this would just be for sh!ts and giggles
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old April 10th, 2008, 04:03 PM
Ragland's Avatar
Ragland
Robert Ragland
1994 Defender 90
The tire on the hood has a classic look. I wouldn't, however, make this a decorative feature. Sounds a little too much like a continental kit. It should work nice with 255's, though.
"Uhh...I think they all leak like that."
Old April 10th, 2008, 04:15 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Yep, I don't want to go overboard. Next thing you know I will have curb feelers mounted
Old April 10th, 2008, 05:00 PM
61rover's Avatar
61rover
John Crouse
Bonnet Mount
Check with Rob Dassler (Roadsiderob on here). He added the bonnet mount on a D90 and I think had some second thoughts.
Old April 10th, 2008, 05:34 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
I'm sure you guys know this, but if you put a tire mount on a NAS Defender hood with any good size tire you will not be able to open the hood because the tire mounts are designed for Euro Defenders that do not have the roll cage in front of the windscreen. The tire will hit the roll bar before the hood opens all the way.
Also most kits are missing the needed 2 extra hood supports and the different hood prop that are required for safe operation. The stock NAS hood prop is made for just the weight of the hood itself and can collapse, had one almost take my hand off. The hood mount prop is a long straight rod that is tougher.
Just FYI.
Email:
Old April 10th, 2008, 08:21 PM
themaxx's Avatar
themaxx
Ade
94 ST
Burke, Alex had one for sale, not sure if he sold it though...
Old April 11th, 2008, 12:43 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Honestly, I would not recommend it unless you are running 235/85 or 7.50's. Any bigger will effect you vision. It may work for some but I hate it. I'm 6'3 and run two in risers on the seat and I still think it blocks my vision off road. Plus if you run of bad roads a lot it will take a toll on your hood, mine gave out in baja once and it sucked.
This is all of course my opinion, but I have a mount and I don't run a tire there. Sure it looks cool but not worth it to me. I'm actually in the the process of adding a second spare mount to the rear...
Old April 11th, 2008, 09:27 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Ok, you guys talked me out of it, just what I was hoping you would do. Thanks, saved me some change $$$
Old April 11th, 2008, 09:52 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I have a spare mount on the bonnet on my series III and I took the tire off because I found I was less likely to open the bonnet to check the fluids knowing that I had to lift that heavy mother every time.
Old April 11th, 2008, 10:43 AM
I have 255's with the steels on my hood. I put down chequer plate before I installed it to spread the weight better, and it has worked very well. I love it and love the look. I'm 5'8" and find no issues driving with it on there. It is a heavy mother, but I can do it myself. I keep a roll of electric tape on the bonneet release handle, and slide it on the shaft before I pull it to keep it out while I go around front to release my bonnet latches and lift the bonnet. I much prefer my spare there than on the rear door. Now I have a spector can mounted on the rear door, that I keep empty except when I run off road, to minimize strain.
My kit came with the new hood prop, but I haven't switched it out yet. Based on Mike's comments, maybe I should, but it's holding solid for now. I can also fully open my hood with the tire mounted, without any impact to the cross rollbar, so I'm confused why some have a problem there. Maybe it's with the new prop.
Regardless, I definitely wouldn't put a different size spare on the hood just for looks. it's extra weight and hassle with no upside, and Defender owners should have an anti-bling ethos. Everything should have a purpose...multi-purpose is even better.
Name:	110 front right step closeup small.JPG
Old April 13th, 2008, 12:53 AM
jabber
m j
110
Had a bonnet mount spare with 255/85 on a steelie, on my old 94. It sucked!!! I could open the hood, but it was hella heavy. It also rattled like a bitch off-road. I wouldn't do it again.
mount, spare
Bonnet Mounted Spare Tire WLDKGDM Wanted 6 May 14th, 2009 03:39 PM
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
hood mounted spare tire holder GeoParth Wanted 3 October 13th, 2005 07:07 PM
spare tire mount bonnet Abrooks For Sale - Parts 14 April 30th, 2004 11:01 AM
Bonnet mounted spare tire flippedrover Misc. Chit-Chat 32 December 15th, 2003 06:37 PM
