Black freestyle rim pictures? - Defender Source
Old April 23rd, 2012, 08:57 PM
Abrooks's Avatar
Abrooks
Tony Brooks
With new 285s going on the truck, it's a good time to consider what wheels to put them on (truck is a ROW 90 truck cab) I currently have black 5 spoke steel wheels, the typical ones you see on ROW trucks. I also have a set of freestyles. Considering the truck is "Arizona tan", silver alloys make look strange. So im wondering if it's worth painting or powder coating the freestyles black. Anyone done this on a brown truck? Anyone good with photoshop? Any suggestions?
Old April 23rd, 2012, 10:54 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
I've just been reading a bunch recently on powder coating alloy wheels and there is some concern on the heat and the hyper-aging of the metal. Basically making it brittle. Seems hard to get a straight ok or not since it really depends on the alloy itself and it's original aging temp used.
Looks like many people have powder coated with no issue. Just thought it was interesting and there is engineering truth behind the concern.
Old April 24th, 2012, 06:44 AM
Damn Jeff... You could be the new "Josh".
Old April 24th, 2012, 11:04 AM
Tony I have some flat black freestyles with 285s on them if you want to see what they would look like on your truck
Originally Posted by pendy
I'm here for the D's
Old April 24th, 2012, 12:55 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Got a picture of your truck with them on, Charles?
Jeff, I should be so lucky that axle snapping would be a concern of mine. . .
Old April 24th, 2012, 01:07 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Spray some plasti-dip on 1 or 2 of the wheels and put them on the truck, you can just peel it off when you want to remove it, and you don't need to sand anything, just clean the wheel first.
Old April 24th, 2012, 01:10 PM
Abrooks's Avatar
Abrooks
Tony Brooks
John, you're the second person to suggest that -- might be worth a try.
Old April 24th, 2012, 01:13 PM
JohnsD90's Avatar
JohnsD90
It's $6 a can at home depot, it is easy to spray on, and fairly easy to take off. I've used it a few times, not much a risk of using it at $6.
Old April 24th, 2012, 01:18 PM
Ok, I forgot only one was a freestyle and it was the spare so you don't see it here. But here it is with the other kind of alloy, whatever they are.
Old April 24th, 2012, 01:25 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Charles, thanks for that, we may have a winner. John, how does the plasti-dip wear?
Old April 24th, 2012, 01:35 PM
Negative. All I have done is commit to making a new frame (by cutting off the rear cross member). It's one of the things I have promised myself to finish before moving on to other things. Just need to build a new frame, a nose box, disassemble, galvy it all, paint, re-assemble. I really wanted to put some drawers in it as well.
Old April 24th, 2012, 02:11 PM
draaronr's Avatar
draaronr
Here
LR3
freestyles and the xs deep dish
ID:	50704   Click image for larger version
Old April 24th, 2012, 02:27 PM
Did someone call my name?
No charge for this one.
Old April 24th, 2012, 02:31 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Josh,
That is more like Photochop.
------ Follow up post added April 24th, 2012 02:31 PM ------
What process did you use on these?
Old April 24th, 2012, 02:34 PM
Abrooks's Avatar
Abrooks
Tony Brooks
My GOD I thought for a second someone had stolen my truck! GENIUS!!
I seriously hope you're not poking fun at my skills.
Old April 24th, 2012, 02:35 PM
JohnsD90's Avatar
JohnsD90
I've had it on a plastic valence for over a year now with no chips or scrapes from salt ice or road debris, but i accidentally got some chrome polish on it and it stained and won't come off (but i could just spray over that), so most people say to clear coat over it.
Old April 24th, 2012, 02:36 PM
Abrooks's Avatar
Abrooks
Tony Brooks
I might have to stop at the Depot on the way home . . .
Old April 24th, 2012, 02:37 PM
draaronr's Avatar
draaronr
Here
LR3
Originally Posted by tjfslaughter View Post
Josh,
local powdercoater did the the work, sand blasted then powdercoated with a gloss finish on the deep dish and a matte on the freestyles.
Old April 24th, 2012, 03:00 PM
can you do my truck with black powder coated boosts?
ac
Wanted: 1 Freestyle Alloy Rim WLDKGDM Wanted 1 June 10th, 2009 01:32 PM
Looking for 2 Freestyle rim hub caps.. TDI Guy Wanted 5 November 13th, 2008 08:32 PM
Freestyle Alloy Rim roverboy Wanted 2 August 18th, 2005 11:48 PM
37" MTR and Safari Gard rim tbmcneill For Sale - Parts 1 June 3rd, 2005 09:38 PM
