Bimini Top - Defender Source
Old July 28th, 2006, 02:17 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
Bimini Top
I'm almost embarassed to ask this...but I can't seem to figure it out:
Where is the correct place to tie down the rear straps of a bimini top? I've been securing the straps through the mounting brackets of the back seat for some time now, but part of the top will remain loose and flap in the wind. I've seen pictures of D90s with the bimini top secured somewhere near the rear speakers, but can't seem to figure out where. Is there some bracket back there that I don't have?
Old July 28th, 2006, 02:24 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Your missing the brackets that mount next to the tail gate on each side. you should have 2 small holes the bracket screw into. I think the jeep brackets will work.
Old July 28th, 2006, 03:30 PM
badgerman's Avatar
badgerman
Christopher Laws
1964 Land Badger
You can mount footman loops on top of the bed cappings (either side of the tailgate) with screws or bolts. You can probably find these items at a boat supply store.
Sew on and sew forth...
Old July 28th, 2006, 03:38 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I did the same tie down method for a few years with my top and you are right the center rear of the top flaps like crazy. The fix is to purchase two footman loops from any jeep supply catalog. My 90 did not have pre drilled holes so I had to drill and attach the footman loops. The location is along the top of the rear tub just above the speakers between the rollbar and opening for the rear tailgate. If you pull on the bimini top straps you can figure out exactly where to place the loops so the top does not flap. Do yourself a favor and get the stainless ones because the steel ones rust.
Old July 28th, 2006, 08:06 PM
jordan0527's Avatar
jordan0527
Jordan
97 D90 ST, 04 D2
Thanks for the help....the holes are already drilled, just missing the brackets / loops. Had a hunch those holes were there for something. I'll check out a Jeep supply catalog as you suggested.
Best
Jordan
Old July 31st, 2006, 09:57 PM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
I have mine wraped around the cage inside the tub. The cage drops into(Through)the tub just to the outside of the speaker boxes. Easy to work with and no drilling.
Old August 1st, 2006, 10:34 AM
Seanh has it right. That works too.
LR Bimini Top (LRNA71725G) FOR SALE jam90 For Sale - Parts 1 December 12th, 2005 09:53 PM
Land Rover bimini top snaps jam90 Defender Technical Discussions 2 July 7th, 2005 01:49 PM
Source for Bimini top?? ronward Defender Technical Discussions 7 September 6th, 2004 05:11 PM
D-90 Bimini Top & Waterproof Seat Covers MDS Wanted 0 August 7th, 2004 07:11 PM
Bimini top & half Tonnaeu Top doozle Wanted 0 July 29th, 2004 10:59 AM
