bed liner? - Defender Source
Old July 15th, 2007, 08:53 PM
1000kva's Avatar
1000kva
paul girard
bed liner?
I am looking at different options on the spry on bedliner. Does anyone have any feed back on any of the companies and various diy stuff out there? I have seen a new clear spray on liner that seems great but it is about $800 installed. I have also found Rust Guy Rust Converter which looks like it might be good as well - could even be a good underbody coat for your 90 .
Old July 15th, 2007, 10:46 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Do some searches, lots of people have done this. Herculiner comes to mind. If you're going to line the rear tub, you might as well line the whole thing while you're at it.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old July 15th, 2007, 11:12 PM
themaxx's Avatar
themaxx
Ade
94 ST
Search for Line-x and Rhino liner. I've heard mixed reviews regarding the Herculiner...flakes after sometime. Line-x and Rhino can now come close to matching the color of your truck if you wish.
I had my entire truck Line-x'd for around $750 or so. You might want to considering putting in some dynamat to deaden the sound in the truck before having it sprayed on. Over all, it may not be cheap, but from what I've read here, it's worth it.
Cheers!
Old July 20th, 2007, 10:27 PM
D90DRC
D Cantrell
1997 D90SW
I have to go Line X the texture UV and price seems to be more competitive. I'm kicking around the idea of doing my Hood and Roof in Vulcan Black, inner Roof in gray...
Old July 20th, 2007, 10:52 PM
I did the inside of my jeep cj with herculiner several years ago. hasn't flaked one bit. Thinking of doing same to my 110. I added silica sand to it as well, to give it a grip texture.
Old July 21st, 2007, 10:04 AM
brn24whl's Avatar
brn24whl
Eric
1994 RRC SWB
I did line-x on entire inner tub, all floor panels top and bottom, and the entire seat box (top inside and bottom) in light grey. It looks awesome and was worth every penny. I'm kicking around the idea of doing the sliders, corner protectors and trailer hitch in black.
Eric
Eric Riston
1-800-533-2210 ext 231
Direct Line 518-539-2231
Old July 21st, 2007, 08:32 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
I did Rhino Lining, and if I had to do it again, I would use Line X. Cleaner application and the finished product is cleaner looking. From my understanding Line X does not drip, while Rhino definitely does.
I initially bought Herculiner, but as soon as i busted open the can and looked at the stuff, I decided that if I was going to do something that`s a permanent installation, I didn`t want to mess around. I paid $700 i think it was. Worth it. It`s nice being able to hose down the interior.
Old July 22nd, 2007, 01:17 AM
themaxx's Avatar
themaxx
Ade
94 ST
Nate is right, Line x does NOT drip. If you have the time go and check out a dealer near you. The one I went to, had a Pepsi can that they Line x'd. You could stand on it...stomp on it all day, it wouldn't crush under the pressure. They showed me this cool video on how the Airforce is now using it to bomb proof walls of buildings. They can mix it so that it grainy or more on the smooth side.
I can't say enough about this product. People use it around their house...spraying it on deck stairs and anything that can be thought of.
Old July 22nd, 2007, 09:55 AM
Treuwer's Avatar
Treuwer
Trae Reuwer
94 D90
watch your hootus if you do it yourself.
Old July 22nd, 2007, 05:20 PM
1000kva's Avatar
1000kva
paul girard
I ran across that hootus thread as well, rather unfortunate for the guy.
Old May 13th, 2009, 04:08 PM
RyanB16's Avatar
RyanB16
Ryan Hoffmeyer
94 D90 Red HalfCab #741
I was just wondering if bed liners de-value the defender? a permanent aftermarket add-on that is not a stock item. does this effect it in any way?
Old May 13th, 2009, 04:15 PM
IMHO yes and to a high degree, especially if you do not spray the pieces seperately so that you can access all the bolts and such (ie make it so you can still take off the seat box, floor boards, cage parts, rear bed trim strip etc.).
Old May 13th, 2009, 04:18 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Depends upon how its done. If everything is sprayed, including fasteners and seams between components, it would make it a royal PITA to take stuff apart. If done 'well', so that future disassembly is not hampered, then it could be OK to positive.
edit: Ron beat me to it.
Rebuilding a v8 engine - how to fix liner problems robisonservice Defender Technical Discussions 10 August 19th, 2006 10:18 PM
Door entry guards and cardo liner rustydefender Defender Technical Discussions 15 January 8th, 2005 11:41 AM
installing bed rail kit TDI Guy Defender Technical Discussions 2 November 3rd, 2004 07:28 PM
Line X / Spray In Liner ? rcmorgan540 Misc. Chit-Chat 10 June 1st, 2004 02:49 PM
speed liner or rhino liner TDI Guy Misc. Chit-Chat 5 May 5th, 2004 09:27 PM
