back spacing - Defender Source
Old November 2nd, 2005, 09:19 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
Question back spacing
I know I am probably dumb, but what is the back spacing for on a wheel? Does it make it stick out further to help bigger tires not rub?
That is why it is called a short cut. If it was easy it would just be "the way."
Old November 3rd, 2005, 01:08 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Remember, there are no stupid questions. Just stupid people. JK. Backspacing is simply the term used to describe how far the center of the wheel is from the inside lip. For instance, if you had 0 backspacing, the tire would stick out dramatically. Wheels have various backspacing, so if you pick the correct one, the tire will not rub any suspension or steering components. Or, if you care at all, not stick out too far.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 3rd, 2005, 08:06 AM
Found this, explains a bit about wheels and all the terms for us stupid people
http://www.rsracing.com/tech-wheel.html
ac
Ron's back with another D90! evilfij Misc. Chit-Chat 18 June 7th, 2005 08:53 PM
Back lights all out vnrover Defender Technical Discussions 7 June 21st, 2004 12:04 AM
Back Door Rattle mdmccallum Defender Technical Discussions 7 December 19th, 2003 12:55 PM
