AUX Light wire routing - Defender Source
Old September 26th, 2006, 10:06 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
How do you guys route the wires up to the 4 lights on top of the roll cage? Pics would be great. Thanks.
Old September 26th, 2006, 10:18 PM
I ran mine on the outside and covered them with that plastic cable wrap from Home Depot. I have seen people who have drilled a hole behind each tab and ran the wires thru the rollbar. If you do it the second way, you are going to have to remove the front part of the cage and drill a hole thru the inside of the fender to get the wires out of the roll bar. I hope I have not confused you with this explenation. I wish I had some pictures of the thru the bar thing. Good luck.
ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Aux Light Mounting Bar mod4b Wanted 9 July 18th, 2005 01:48 PM
Aux Light Wiring Frustratio ronward Defender Technical Discussions 4 August 23rd, 2004 06:53 AM
