Aux 12v dash trucker fan - Defender Source
Old June 2nd, 2015, 02:29 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
My wife is getting prepared for many road trips in the 110 and is looking at trucker fans to mount in the dash. At speed there is plenty of airflow, but at low or no speed no airflow. So.....has anyone installed a dash fan for cooling occupants or at least providing additional air flow?
Old June 2nd, 2015, 03:08 AM
El Solis's Avatar
El Solis
Chris Solis
Camel Trophy 110 sorta :)
I wired up one of those fans for my son in the red seat. Works fine. Makes a big difference when the going is slow. Probably the easiest way is to get a clip on one and install a blue sea (or vendor of choice) 12V socket through an aux fuse block. You will still be warm tho.
Old June 2nd, 2015, 07:43 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You could try the poor mans AC by keeping a frozen gallon milk jug in a cooler with air blowing in and out.
You could also keep the engle on freeze to have a reserve frozen to swap out as needed.
We used one for camping and it worked great for sleeping in the summer.
RDavisinVA
Old June 2nd, 2015, 09:31 AM
LR Max
Thomason, Max
1973 Series 3 109
Yeah the fan works ok. I got one that claps and clamped it onto the dash.
X1 on the swamp cooler mentioned above. That'll be the best solution. Also cheaper and easier, simply throw a bag of ice in the floorboard. It'll last only a few hours but its worth the few bucks.
Sutars Recessed Flush Mount 12v sockets Uncle Douglas The Flea Market 14 August 23rd, 2012 09:25 PM
Compact 12V Breaker Panel? ajh Defender Technical Discussions 8 February 21st, 2009 06:09 PM
Portable 12v air compressor options pmd Defender Technical Discussions 12 April 8th, 2007 07:01 PM
Portable 12v A/C-swamp coolers kellymoe Misc. Chit-Chat 0 May 24th, 2005 06:59 PM
Switched 12v ignition and drive? dmarchand Defender Technical Discussions 4 December 23rd, 2004 10:23 AM
