ARKONIK's Response to: Homeland Security took my 110 - Page 16 - Defender Source
Old November 29th, 2015, 05:32 PM
phoenix37's Avatar
phoenix37
john
for starters build tolerances...I just did the factory tour and as I think Craig stated early Defenders have a build tolerance of a 1/4 of an inch...compare that to a new range rover that has a build tolerance of a fraction of a mm..... thats alot of room to get wet.
Old November 29th, 2015, 05:52 PM
jason1st
Jason Crandall
2006 LR3 2012 SC 1983 110
I don't know why you're having so much trouble understanding what I'm saying.
"Build tolerance" at the factory has absolutely nothing to do with a $100K Defender build.
You're telling me the $175K Spectre Defenderleaks because of the build tolerance of a new one at the factory?
When you take something apart and the re-build it as new with a bunch of money you raise the "build tolerance".
Hence why I say "a $100K restored caddy has a better build tolerance than it was when it left the factory new".
Old November 29th, 2015, 06:07 PM
phoenix37's Avatar
phoenix37
john
I get what you're saying....trust me for 100k I would also want a 400hp 6.2 LS powered 110 with a puma dash etc etc but Im not sure why you aren't understanding that vehicle can't be brought in the country... yes it could be built here but not imported.
how do you change the tolerances of body panels?
Old November 29th, 2015, 06:12 PM
Because of the loose build tolerances more adjustment is required to get it right. Anyone can bolt a Defender body together, but very few will spend the time to make it right. Even my Defender is a good example of that. It may be factory, or may be from a shoddy rebuild, but nothing lines up correctly, and because of that it leaks.
Old November 29th, 2015, 06:14 PM
BlackField's Avatar
BlackField
Oscar
D110
Originally Posted by jason1st View Post
What about a Defender makes it impossible to seal up regardless of $$$ spent?
Nothing. Follow the water ingress PDF and get a bit creative. If you don't want a leaky defender and have one, the owner or thier shop lacks the ability or desire to fix it.
Old November 29th, 2015, 06:15 PM
87 D110 (Ruby)
If nuts and bolts hold panels versus seam welding....IT LEAKS
Old November 29th, 2015, 06:20 PM
phoenix37's Avatar
phoenix37
john
Come on guys really? Lets not try and make this truck something it isnt... even if its perfectly water tight when it rolls out of the building that vehicle will get hot...then cold... shrink then swell...the brand new door seals will soften..the door shims will shift and guess what the thing is going to leak...
jeesh...move on.
Old November 29th, 2015, 06:23 PM
the rover shop
shayne young
In order to make a 25-30 year old defender NOT leak you basically would have to redesign the way it is assembled...sure, we could use seam sealer or 5200 on the floor panels and spoodge rtf into the areas where they go together to get a water tight seal, but there are going to be functional design items that are prone to leaking, the windscreen frame to bulkhead seal is one, you cannot redesign the fact that where the two pieces come together there is a break in the continuity of the metal that has to have a door seal go over it..it's gonna leak...the bulkhead vents, use em a couple of times and they can leak... As I mentioned before, if you actually built one of these you would see that it's not as simple as.."make it not leak"... Sure, it could be done, but them people would be bitching that they can't pull their floor panels out to access the tranny etc etc..there is a shitload of joints and thru holes in the body of a defender.. As mentioned, that's why they made pull out mats, it wasn't because Land Rover couldn't make the defender water tight...its that it wasn't on the list of priorities for the use specification of what the truck was meant for...and the modular design to allow it to be made in different configurations... And I would bet my bottom dollar that the specter does indeed leak...how much, I don't know.. The gaps in the floors aren't there to let the water in...its to let the water OUT..
Old November 29th, 2015, 06:24 PM
87 D110 (Ruby)
Then fix it! Oh, thats right....I don't think you can.
Not picking on you mate - just saying it can't be done. I don't care how much you spend....anint no way you will make a Defender waterproof.
Old November 29th, 2015, 06:25 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
This whole thread is fucked up…it is not hard to solve the water ingress on these trucks, especially when your paying a company to make it right. The red 110 we restored doesn't leak, why, because we spent the time to make sure it didn't. You cannot compare a rebuilt truck to a factory build, it should be much better.
For you guy's to be arguing about this is hilarious…stop defending the fact that this shop sucks ass…
Quick edit:
Most dropping 75k plus on a rebuild is not going to even notice if the floor panels have been assemble with seam sealer...
Old November 29th, 2015, 06:26 PM
Exactly.
I've had to pull the entire interior out of newer Land Rovers to look for water leaks. Sometimes it is quick, sometimes it takes many hours. It takes two people to diagnose water leaks. One person inside the vehicle (with the interior trim removed) and one person on the outside with a garden hose slowly spraying every inch of the vehicle. Sometimes we have to leave a hose spraying on the roof for hours before water will start leaking inside the vehicle.
Old November 29th, 2015, 06:29 PM
87 D110 (Ruby)
Exactly.
what about a smoke test? Seems like that works pretty well
Old November 29th, 2015, 06:32 PM
You seriously think that I couldn't fix the water leaks in my Defender? The top of the rear door doesn't touch the door seal and I can see daylight out of the top of the driver's door when driving. I live in the city and don't have a garage. Any work I do on my Defender pretty much needs to be done in less than 4 hours at work. I have no carpets, so water leaks aren't a huge issue for me.
I did just fix my vent seal leak that was caused by someone's 'custom' seal that didn't fit properly. I replaced it with a Genuine seal and the leak stopped, imagine that!
------ Follow up post added November 29th, 2015 07:34 PM ------
I've never heard of doing that, but I guess it could work. I've heard of ultrasonic testing.
Old November 29th, 2015, 06:36 PM
phoenix37's Avatar
phoenix37
john
Quick edit:
it doesnt leak because you live in Arizona for the record I'm not defending anyone... just yet to see a defender that is leak free..
Old November 29th, 2015, 06:59 PM
jason1st
Jason Crandall
That's exactly what I've been saying the last 2 pages.
------ Follow up post added November 29th, 2015 08:02 PM ------
There's more to a build than "leaks".
The point of this whole thread is "what do you get for your $$$" in Defender land and the people doing business in Defender land who use this lame excuse for shitty workmanship.
Old November 29th, 2015, 07:07 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
Oh it's rains here...and there this thing called a hose...
Just sayin' it's not hard to do if you look at it realistically. How many will be taking apart their 75k defenders in the bush...
Old November 29th, 2015, 07:16 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Who are the guys that went to Arkonik?
The ones on the quasi-defensive side of this argument? Mwahahaha...
You little rebel, I like you.
Old November 29th, 2015, 07:28 PM
the rover shop
shayne young
one mans quasi knowledge is another mans knowing what he's talking about due to actually having been there seen that... instead of just talking out his arse about something he knows jack all about...
Old November 29th, 2015, 08:04 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Come on guys really? Lets not try and make this truck something it isnt... even if its perfectly water tight when it rolls out of the building that vehicle will get hot...then cold... shrink then swell...the brand new door seals will soften..the door shims will shift and guess what the thing is going to leak... jeesh...move on.
Exactly - you are talking thin gauge aluminum sheet (and not the greatest grade) that is pop riveted together with some spot welds here and there.
Add those body pieces to a ton of other little parts that are bolted and pop riveted together and that is a Defender. O yeah - many of those parts work amongst a bunch of different models/configurations.
Like Shayne said they are made to be broken down quickly and with very basic tools. My Suburban is sealed up like a duck's ass but I would not want to change it from RH to LH drive or pull the TCase in my driveway.
When I rebuilt my tub I kept thinking WTF did LR build it that way? Well with a break and a rivet gun you can put one together and probably teach a 4th grader how to do it. Look at some of Ash's work and see how much nicer it could be.
Old November 29th, 2015, 08:11 PM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Leak proofing.
http://www.landroverweb.com/Pdf-file...ess_Manual.pdf
Homeland Security took my 110 C391HAT Misc. Chit-Chat 2371 July 15th, 2017 09:15 PM
