Anyone used "Lowmileageparts.com"? - Defender Source
Old May 16th, 2016, 09:37 AM
Shagey71's Avatar
Shagey71
Sam Hagey
1995 RRC LWB - Alpine White
My RRC has 221,001.8 on it, as of pulling into my spot at the office today.
The heads were done about 50k miles ago, but I just can't keep the damn thing from hemorrhaging oil any longer. Okay, maybe not hemorrhaging, but it's not just a rover drip anymore. That, and I'm probably down to only 150hp or so at this point if I had to guess.
I'd pay up to $2k for a quality used motor to go through, refresh, and drop in... So I found this place.
Anyone heard of em?
1995 LAND ROVER RANGE ROVER Engine
Rovers, Guns, and Airplanes... Willing to share my Ramen Noodle Recipes!
'95 RRC CountyLWB - dripping all over central TX
'83 110 HCPU - in piceces, all over central TX
'90 RRC Truggy - loud and proud
'95 RRC CountyLWB Beluga Black - SOLD
'01 P38 - POS Leaked Electricity - SOLD
Old May 16th, 2016, 10:28 AM
If you are llooking for something to use as a rebuildable core, free or sub-$500 is what you should be paying. Is yours currently a 4.2? I guess that might command a little higher $$. But I think $2k is a lot.
Anyone heard of em?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 16th, 2016, 10:49 AM
Shagey71's Avatar
Shagey71
Sam Hagey
If i can get a solid low miles 4.2 (mine is currently a 4.2) that I can put another 150k on, (my tranny is almost new) then I'll pay more than $500.
I'm on the edge of calling Nick for the LS swap adapters, but as much as I love my truck, I'm constantly reminded it's "just" a RRC and that a $10k motor swap may not be the smartest move to make.
Old May 16th, 2016, 11:32 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
How much oil are you losing that you're thinking about swapping the whole thing??
Where's it leaking?
Rent my
Old May 16th, 2016, 11:54 AM
Shagey71's Avatar
Shagey71
Sam Hagey
Where's it leaking?
The rear main is barely holding on. I've band-aided the rest sufficiently and am fine with it, but that rear main is, for lack of a better analogy, like a 70 year old woman in heels under a stop light on the south side.
I drive it like hell anyways, and after 1200 miles in 20 hours, the tailgate had some oil on it...
and I was down about 3/4 qt of 15w40. I have since towed the 110 on a 1ton trailer 600 miles with it, and lost about 1/4 qt.
Old May 16th, 2016, 12:43 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
The rear main is barely holding on. I've band-aided the rest sufficiently and am fine with it, but that rear main is, for lack of a better analogy, like a 70 year old woman in heels under a stop light on the south side..
South side? All this time I thought Rundberg was the spot.
Black Rhino Lives Matter
Old May 16th, 2016, 01:26 PM
Shagey71's Avatar
Shagey71
Sam Hagey
The spot for what? If the answer is losing your radio and anal virginity under the moonlight in one stop, then yeah you're probably right.
Old May 16th, 2016, 05:40 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
You know... it might not be a rear main seal.
On these motors the crucifix seals can lead you to think the rear seal is bad...
Rent my
Old May 16th, 2016, 06:01 PM
Shagey71's Avatar
Shagey71
Sam Hagey
Clueless. Googled. Found Seal. still don't know where it goes or what it does. will google more.
Smells like yanking motor is necessary regardless.
Drats.
Old May 16th, 2016, 06:24 PM
pl626's Avatar
pl626
Peter
1995 Range Rover County SWB
2k is pricey for a low mileage used. You should be able to find one for less than 500. I bought a complete truck with low mileage powertrain, 4.2, for about 2k. I also bought a 3.9 w/ ~ 135k for less than 300. She's still running strong, with more than 6k miles. If you're ok spending 2k on a used, I'd rebuild the block you already have.
Cheers,
pc
'95 RRC SWB
'95 RRC LWB (Sold)
'06 E350 Sport
'87 HD FLST w/ '02 Fatboy sheetmetal
'02 Hobie Getaway
Old May 16th, 2016, 06:38 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Drats.
Crucifix seals can be redone(RightStuff) in a few hours...only dropping the sump pan.
Rent my
part, parts
" Wolf " Style Steel Rims 6.5" X 16" 2 3/4" javelinadave For Sale - Parts 3 January 27th, 2014 08:36 AM
Wanted: SW Roll Cage RH "horn" or POE "horns" JimC Wanted 8 December 5th, 2006 03:35 PM
"94" RRC SWB County $9,500 "ish" shawom For Sale - Vehicles 0 October 18th, 2005 08:39 PM
Difference between "WOLF" and "NATO" wheels? wicks Defender Technical Discussions 10 August 12th, 2005 04:23 PM
OME springs: "A" and "B"?? jaherring Defender Technical Discussions 3 October 30th, 2004 05:49 AM
