Anyone Running Goodyear MT/A 285/75s? - Defender Source
Old April 25th, 2015, 04:26 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Not sold on the 255/85 for my new 110 build and would like to be slightly wider. I found the Goodyear Wrangler MT/A in 285/75 which gets me another 1.5" in actual tread width. Anyone running this tire right now with a 2-2.5" lift?
Semper Fi!
Old April 25th, 2015, 04:34 AM
I'm running 285/75 r16s in a different mud terrain. Not sure what your brand specifications should have to do with it unless you're just looking for pictures of them mounted on a Defender? I also have a 2-2.5 inch lift and run spacers in the front.
Old April 25th, 2015, 05:24 AM
Wolf Fabrication
Sterling Archer
'08 D3
Doesn't have to be GYs. I didn't see many other manufacturers in that size. Mind throwing up a pic?
Semper Fi!
Old April 25th, 2015, 07:26 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
What size spacers are you using. I have 265/75 KM2's that do a fair bit of rubbing on the radius arms.
Thanks!
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old April 25th, 2015, 07:56 AM
Thanks!
Try adjusting your steering stops.
Old April 25th, 2015, 08:57 AM
Pics in my registry. Boosts with BFG MT KM2s in 285/75 R16 with spacers from EZ Accessories, and KM1s in the same size on black steel ANR1534 wheels with no spacers.
Old April 25th, 2015, 07:12 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
285-75-16 with 2" HD TF springs. No rubbing, no issues so far
Old April 25th, 2015, 07:14 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
Damn Apple!
Old April 25th, 2015, 07:26 PM
Originally Posted by jayz View Post
Damn Apple!
Hanging your rover upside down is one cure for tire rubbing
Old April 25th, 2015, 07:33 PM
Wolf Fabrication
Sterling Archer
'08 D3
Thanks for the pics. The stance is exactly what I'll have, and I like how the tires still fit within the flares. My truck is Arles Blue too!
The 285/75 requires a 7.5" or wider rim, but I am running TF Anthracite wheels which are 7" wide, of if beadlocked 8". Anyone have any issues with mounting them on a 7" rim? I assume that .5" won't matter...
ID:	119191   Click image for larger version
Semper Fi!
Old April 25th, 2015, 07:36 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I would but I don't want to make my turning radius any worse than it was when it had 7.50 X 16's on it.
Old April 25th, 2015, 07:39 PM
jayz's Avatar
jayz
Jason Zolezzi
85 200tdi 110
sure thing. The combo seems to work well
Old April 25th, 2015, 07:45 PM
Wolf Fabrication
Sterling Archer
'08 D3
You're not making it worse, you are just adjusting the stop so the tire doesn't rub the radius arm. The affect on turning radius is negligible.
Semper Fi!
Old April 25th, 2015, 08:00 PM
Greenbull's Avatar
Greenbull
Mark Miller
1994 Defender 90NAS #1258
Hmmm
I don't know? My turning radius sure got a lot wider when I adjusted mine...
Old April 25th, 2015, 08:11 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
My turning radius got noticeably wider and now tires rub with the new 265's. Correct me if I'm wrong, wouldn't wheel spacers alleviate the rub while tightening up the turn radius?
Old April 25th, 2015, 08:13 PM
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by Greenbull View Post
Hmmm
Whether the tire stop is adjusted properly, or the radius arm is acting as the tire stop, the difference between the two is minimal. Simple geometry.
What's affecting your turning radius is tire size and wheel offset.
------ Follow up post added April 26th, 2015 09:21 AM ------
Yes, your turning radius will change with different wheel and tires, especially if they now rub. Wheel spacers will help a lot.
The point I was trying to make is that if your tires already rub, adjusting the stops properly won't significantly change your current turning radius - but they'll keep your tires from rubbing on the radius arms.
Semper Fi!
Old April 29th, 2015, 11:15 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
goodyear wranglers with kevlar sidwall
Hi, I have been using them for a few years now and just had a new set installed on my truck this last saturday. My truck has an old man emu 2" lift . The tires have worked well for me in deep powder dirt, loose and hard sand, rocky roads and highway pavement. I use to run goodrich MTs until the new tread design came out. That is when I switched over to goodyears tire. I actually lost two of the goodrich MTs to sidewall thorn punctures out driving through the high desert areas in Owens valley, CA / no more thorn punctures with the kevlar sidewalls. I attached some pics for you.
ID:	119479   Click image for larger version
ID:	119481   Click image for larger version
ID:	119483   Click image for larger version
Old April 29th, 2015, 11:42 PM
Len! Glad to see you're still lurking around.
Old April 29th, 2015, 11:57 PM
Wolf Fabrication
Sterling Archer
'08 D3
Great pics, thank you! That's the size I've decided on.
Semper Fi!
Old April 30th, 2015, 01:41 AM
LenB's Avatar
LenB
Len Bruffett
You're welcome for the pics. . When shopping for the tire I got the lowest quotes directly from a local goodyear tire service center. around $230 a tire - no waiting to get the tires either... they had them in their local warehouse + they were freshly made "03/15" When I bought goodrich tires they always had to be ordered and I occassionaly would get 3 good tires and one old stock - dried out tire....the shops could never balance the old stock tire because it had outgased unevenly - so they would have to order an additional tire. (This occurred on two different sets of goodrich tires at America's tires.
Anyone running 285/75r16's? bitz Defender Technical Discussions 44 May 14th, 2009 12:23 AM
White steel rims with 315/75s ini88 Misc. Chit-Chat 12 September 30th, 2008 06:10 AM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
Anyone Running Koni RAIDs on a D-90 Shake Defender Technical Discussions 12 January 7th, 2007 04:54 PM
Tires, anyone running 35x10.5 16 SSR's btate Defender Technical Discussions 30 October 20th, 2006 11:20 PM
