anyone have experience with rpi? - Page 2 - Defender Source
Old April 1st, 2005, 10:59 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Dear Mr. Moderator,
If you should happen to glance at this thread I would love to hear about your 4.6 install. I'd like to hear what kind of problems you have run into, or anything that you might do different if you had it to do all over again. If you feel uncomfortable posting about it because of your position here, or want me to mind my own damn business, no offense taken.
Rod
Old April 1st, 2005, 11:47 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
Originally Posted by Bowtracer
John what are you putting the 4.6 into? I think the 4.2 & 3.9 ecus will wok for each other. 4.0 & 4.6 will work for each other.
I have two options:
1. Put the 109 body on the 91 RR frame with the 4.6, or
2. In my 95 D1
John C.
Old April 2nd, 2005, 10:42 AM
Originally Posted by Rod Hayward
Dear Mr. Moderator,
Rod
LOL, it's cool. But I am only installing a 4.0 not a 4.6. But They are pretty much the same, and there are some problems I have run into that I am in the middle of trying to sort out. But from what I have done Ithink the easiest way to go is to make the 4.0/4.6 more like the 3.9, and by that I mean changing the front cover on the engine so you can run with a distributer and a 14CUX ECU. If you want to convert to a GEMs electronic ignition there is 1 big thing I learned, for the GEMs system you need a cam shaft positioning sensor. The sensor has pickups on the flywheel, but if you are like me you have to change the flywheel for the manual trannsmision as most 4.0/4.6s came with an automatic. Well the manual flywheels son't have the pickups. I learned this the hard way. I'll come up with a better list of what is needed and what work is involved when I am done.
Who needs an RPI chip, I'm going "MegaSquirt" Hans Misc. Chit-Chat 25 September 17th, 2007 04:53 PM
OCC's Land Rover Driving Experience WCURoverD90 Misc. Chit-Chat 0 December 5th, 2005 02:54 PM
255/85 wheel spacer experience D90user Defender Technical Discussions 6 July 13th, 2005 11:12 PM
RPI cam or Crane pro's & cons Bowtracer Defender Technical Discussions 1 March 4th, 2005 05:00 PM
Re-Chipping with RPi chip Neo Defender Technical Discussions 35 December 2nd, 2003 12:27 PM
