Anyone have a write up of an LWB ABS removal conversion - Defender Source
Old January 21st, 2011, 03:54 PM
I have the pedal assembly out of a late 88 (lucas type master cylinder) and I have the single input t-piece, what brake lines do I need? Do I need a proportioning valve?
I should have take both off the 88 that peter parted out, but the lines were cut before I got to it.
Old January 21st, 2011, 04:33 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Talk to Daniel INI88. I think he has done this..
Old January 21st, 2011, 06:31 PM
did this on my 91. you can use all the original lines. I had to scab on a few pieces onto the ends of the lines in order to make it over to the other side of the MC
ron, give me a call if you need to. all the lines were cut on the donor truck I used too. The ABS booster has a proportioning valve mounted on it that you can use.
you do need the rear axle t piece too.
Old January 22nd, 2011, 09:23 AM
this manual has excellent diagrams of the braking system layouts including location of the proportioning valve, junctions, booster and pedal adjustments etc. It is what I used to set up mine.
http://www.landroverweb.com/Pdf-file...ual-Brakes.pdf
conversion, lwb
Diesel Conversion Kits and Shops ChicagoDon Misc. Chit-Chat 25 July 31st, 2012 12:58 PM
Diesel conversion - fuel pump removal and new fuel feed jaherring Defender Technical Discussions 0 July 19th, 2010 03:06 AM
Headlamp conversion rustydefender Defender Technical Discussions 21 February 21st, 2005 09:33 PM
D90 wgn - Automatic Shifter T- Handle Removal Kimos Defender Technical Discussions 22 January 18th, 2005 07:05 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
