Anyone have a spare front axle housing - Defender Source
Old November 4th, 2013, 10:53 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
I am looking for an empty front axle housing, anyone willing to let theirs go and possibly cut it up for me? I need the section on each side where the spring perch mounts and the front radius mount as well.
Old November 4th, 2013, 11:04 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
For a later housing (wide arms) looking for a RRC/D1 at your local wrecking yard is probably your best bet. -Jeff
i have complete axle housings at the shop, I just don't want to sacrifice a good housing. Just wanted to see if anyone had one lying around. That where left over from another project.
Old November 4th, 2013, 11:23 AM
rovertrader's Avatar
rovertrader
Dale
Brian, I can cut up one of these RHD housings?? Or, you can run down to see things and take it back with you?
Give me a shout if interested...
Old November 4th, 2013, 11:24 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Originally Posted by rovertrader View Post
Brian, I can cut up one of these RHD housings?? Or, you can run down to see things and take it back with you? Give me a shout if interested...
perfect thanks man
Old November 4th, 2013, 12:13 PM
Roving Beetle
Doug
I also have a RHD housing I'm happy to cut and mail to you. It's going to be recycled very soon.
Series coiler monster in building process, in gather parts mode.
Currently driving an ex-southern 1993 SWB RRC with too much "kit". Massive conversion and interior swap in process.
Lots, lots and lots more have come and gone....
Old November 4th, 2013, 12:14 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
thanks dale has one for me fairly close, if for some reason it doesn't work out I'll hit you up. Hopefully you will still have it
Old November 4th, 2013, 01:03 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
YRM sells the bits new as well if you would rather start with fresh parts.
Axle brackets for front sway bar evilfij Wanted 10 June 2nd, 2013 07:50 PM
Front Wheel Spacer / Axle Question johnpiero Defender Technical Discussions 17 January 11th, 2009 01:36 PM
front axle shafts - are these stock on a 94 d90? cgalpin Defender Technical Discussions 7 July 22nd, 2008 10:25 PM
Front axle swap flippedrover Defender Technical Discussions 15 October 4th, 2007 08:54 AM
blown front end & sucky wheel locks jabber Defender Technical Discussions 6 October 25th, 2004 07:35 PM
