anybody ever done Galvanized capping for NAS 90 - Defender Source
Old September 12th, 2015, 07:17 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile anybody ever done Galvanized capping for NAS 90
I have heard horror stories of bulk heads being warped and was wondering if there is a different process for light metal like cappings
I would hate to send the capping to the galvanizer and have them be destroyed..
good luck with your search
Old September 12th, 2015, 07:22 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
They might be too big but some places use a centrifugal system for smaller parts. I'm about to do my cappings as well and I'm not too worried, there is a lot of structure to them and I think would be less likely to warp. As well the faces are quite small and less likely to get wavy.
Old September 12th, 2015, 07:27 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Do not use V and S Galvinising www.hotdipgalvinising.com if you want all of your parts returned, or if you want the parts they don't lose to be usable, or if you want them to take any responsibility for the work they screw up.
Email is
Same place, new dogs.
Old September 12th, 2015, 07:53 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Go for it! I wouldn't worry about warping at all. I have had multiple bulkheads dipped with nothing but a piece of angle iron bolted between the bottom of the posts no problems. All capping, etc. and frame too... no problems.
The only pain is the left over zinc you have to grind off in places and holes to drill out and tap if needed.
I've only used pacific Galvanizing in Oakland, CA.... that said everything was returned as it was supposed to.
Old September 12th, 2015, 08:44 PM
Ignotus
gene
1960 109, w/200TDI
Shouldn't be a problem with cappings. Take before pics of everything you bring as you drop it off right in front of the receiving guy. I've had 2 loads done at Oakland on 1 they bent the bulkhead by catching a corner on something and just lifting it up with the hoist. I had before pics and after pics. They made good on having a body shop straighten the bulkhead.
Don't just do the cappings as they charge by weight and usually have a min weight. Do everything steel you can, brackets, pedal towers, pedals, radiator support panel, spring perches,...etc The smalls they will put in a perforated bucket and dip then spin dry larger stuff gets wired together.
As for removing excess galvy, heat it up with a propane torch and wipe with a wet rag. I put throwaway bolts in all the threads I wanted to save, just heat the bolt to soften the galvy and remove.
Gene
1960 109
1960 88 Ignotus
Blog;
Old September 12th, 2015, 08:49 PM
Didn't evilfij have literally everything galvanized?
Old September 12th, 2015, 09:22 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
I had a set done back along and came out real good
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old September 12th, 2015, 09:31 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
I had no issues with the cappings. They turned out well. .
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 12th, 2015, 09:36 PM
Mike M's Avatar
Mike M
Mike McC
1990 Range Rover County
Had a similar experience with V and S many moons ago.
Stay away.
Old September 12th, 2015, 09:55 PM
Mine turned out great. Much less warping than my bulkhead.
Old September 13th, 2015, 08:11 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Had 4 sets done over the years and no warping the the cappings they all turned out great.
2 bulkheads I had dipped had some slight waves in them but nothing structural
Old September 13th, 2015, 10:24 AM
ron's Avatar
ron
Ron
Smile
Paul that stuff looks great...... are you going to use it : )
I have 2 frames that I will be dipping a 300 tdi frame and an NAS frame so I have the weight any recommendation in the Boston area?
Old September 13th, 2015, 11:06 AM
lordhelemt's Avatar
lordhelemt
Paul
Haha. Already painted and installed
Sorry got it done down here don't know who to use up there
If you have time I'm doing another run. If you ship me your oarts I can have them done with mine, but it will be a while
Old September 13th, 2015, 11:11 AM
ron's Avatar
ron
Ron
Thanks Paul... since im doing the 2 frames I will put it with that lot.. did they need to be bare metal to dip?
Old September 13th, 2015, 12:51 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
My galvanizer does not prep the material before the process so I have to have mine Chem dipped and blasted prior. Chem dip is great for chassis bc it gets inside and out. Some Galvi companies will do the prep, it all depends.
90, body, nas
Galvanized capping for NAS 90 ron Wanted 5 September 13th, 2015 09:39 PM
Whats the most boneheaded move you've ever done while wrenching? thewap Misc. Chit-Chat 50 November 20th, 2013 02:52 PM
FS: NOS NAS ST RH door & galvanized capping - ALR8104 kiphartzell For Sale - Parts 5 November 5th, 2013 03:27 PM
Have you ever done a Top Gear like powerslide/counter steer in your D90? Neil McCauley Misc. Chit-Chat 5 April 26th, 2012 09:48 PM
I'm done, I'm done, I'm done!!! Grover Misc. Chit-Chat 16 June 13th, 2008 03:27 PM
