Any opinions on Autozone brake calipers for D90? - Defender Source
Old February 14th, 2014, 09:02 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Question Any opinions on Autozone brake calipers for D90?
The calipers that Autozone sells for the front and rear look decent. Anyone have any complaints regarding these? Of course I like the lifetime warranty and the fact that they must be better than the ones I have on now. wachoo tink?
http://www.autozone.com/autozone/par...89_410349_5913_
Robert Deniro
Old February 14th, 2014, 09:21 PM
madcowdungbeetle
Carter
Everyt Duralast rover related part I have seen has been garbage.
Old February 14th, 2014, 09:25 PM
Neil McCauley
Neil McCauley
Yah I figure its not of top notch quality but mine are pretty old. Over 100k miles plus age on my rears. So I thought these would be better than what I have.
Robert Deniro
Old February 14th, 2014, 09:50 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I don't get you. You claim to be Mr. Bentley and now your going to go cheapfuck on something as critical as a brake caliper?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old February 14th, 2014, 09:59 PM
I would just replace the pistons and seals. There's not really much to go wrong and what you need is them moving nicely.
How does someone get to own a Bentley?
Old February 14th, 2014, 10:03 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Did you miss that thread? It's a classic
Old February 14th, 2014, 10:24 PM
Neil McCauley
Neil McCauley
To me D90 is like a toy. I wrench on them more for fun than anything else. And I get a kick on how to keep them running safely at a minimal cost.
Robert Deniro
Old February 14th, 2014, 10:36 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
if it aint broke dont fix it. i have OEM calipers on a Jeep YJ that has 285,000 miles on it. They are 23 years old. They're fine. In a dry climate they can last a very long time.
Old February 15th, 2014, 09:41 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I don't know about Autozone, but I've used Cardone calipers, sold by many autoparts stores, and haven't had any issues.
Well, one issue. The mounting holes on one rear caliper were too small. I guess some model year vehicle that uses the "same" caliper had smaller holes. It wasn't a big deal though, I just stuck it in the drill press and drilled them out to the correct size.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old February 15th, 2014, 10:39 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
The cost of a rebuild kit probably isn't that much less than those calipers.
Old February 15th, 2014, 11:07 AM
If needed, I am pretty sure your can get new pistons with the rebuild kit through Land Rover if yours are pitted. I'd rather have a used genuine calliper than a new Duralast calliper.
Old February 15th, 2014, 12:58 PM
Neil McCauley
Neil McCauley
I just like how they clean them up nicely for you thus saving you some work.
Robert Deniro
90, brake, d90
Series I II IIa III Heystee disc brake conversion kit kullberg Series Technical Discussions 8 June 14th, 2012 03:42 PM
Rear brake calipers staying engaged. FlaD90 Defender Technical Discussions 4 April 12th, 2009 07:29 PM
For Sale - Brake Calipers And Pistons HUMMER80401 For Sale - Parts 6 May 20th, 2006 11:46 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Front Brake Calipers 1of40 Defender Technical Discussions 7 December 30th, 2003 12:46 PM
