Any idea where this is supposed to connect? - Defender Source
Old December 10th, 2015, 01:26 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I just noticed I have a wire hanging coming from a sensor on the driver's side of the engine block. I don't have another truck to compare to at the moment, so hoping someone can tip me off as to where this is supposed to connect?
Old December 10th, 2015, 01:31 PM
oil pressure switch by the oil filter?
Old December 10th, 2015, 01:34 PM
cellulararrest
Chris Snyder
Is there another male spade connector I'm missing? I have the main oil pressure switch on the filter housing, which is plugged in, but this one appears as if it should go somewhere else but I can't for the life of me see where
Old December 10th, 2015, 01:40 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
You don't have 2 spades on your oil housing adapter? I haven't looked at a 3.9 in a while, but there were 2 on mine.
Old December 10th, 2015, 01:43 PM
never mind.
Old December 10th, 2015, 01:44 PM
cellulararrest
Chris Snyder
Just went out checked again and there's only one. Not only that, but that wire won't reach all the way to the other side of the engine to connect to the oil filter adaptor even if there were two spade connectors. There must be another connector somewhere.
------ Follow up post added December 10th, 2015 01:44 PM ------
Sorry for the crappy pics. Can go pull out the real camera
Old December 10th, 2015, 01:50 PM
Just to be clear: You stated "I have a wire hanging coming from a sensor on the driver's side of the engine block"
Is the wire hanging from a sensor, or is it hanging from a harness?
Old December 10th, 2015, 01:55 PM
cellulararrest
Chris Snyder
Directly from the sensor.
Just so I'm not being a totally vague pain in the ass, here's a good shot of the wire from the back of the engine towards the front.
Old December 10th, 2015, 02:05 PM
That doesn't look like a sensor, it looks like a ground wire...
Old December 10th, 2015, 02:07 PM
cellulararrest
Chris Snyder
Actually I think you're right. Base of the alternator?
Old December 10th, 2015, 02:12 PM
I don't think alternators use ground wires. They use the alternator case as ground.
Probably something that isn't used anymore. I would just remove the bolt, remove the wire, replace the bolt, and call it a day.
Old December 10th, 2015, 03:21 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
It grounds the distributor.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old December 10th, 2015, 03:41 PM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
What he said. If its a right angle connector then connects to the distributor housing.
Old December 10th, 2015, 04:16 PM
Rugbier's Avatar
Rugbier
Gustavo
Do you have a remote Ignition Amplifier?
I will bet that is one of the grounds for the coil set up
NO SIGNATURE
Old December 10th, 2015, 04:35 PM
cellulararrest
Chris Snyder
That solves the mystery then. I've replaced my entire ignition with an HEI setup and must have missed that connector.
I'm amazed it took so long to fall down!
Thanks everyone
Alpine DIN radio, SiriusXM connect tuner, Parrot bluetooth kit hillstrubl The Flea Market 1 December 5th, 2015 12:24 PM
Another "It Wasn't Supposed to be a Restoration" project Axel Truck Build-up's & Restores 18 December 29th, 2012 09:20 PM
Quick connect jumper cable mightymg Wanted 6 March 23rd, 2010 11:50 PM
WARN Booster/Jumper Cable Quick Connect Kit pcscharfe For Sale - Parts 8 June 13th, 2009 01:23 PM
How am I supposed to know if I own a Land Rover?? rgrrvr Misc. Chit-Chat 1 May 29th, 2008 07:58 AM
