Anti-theft on a Tdi? - Defender Source
Old March 23rd, 2006, 11:38 PM
Chaucer
Will
93 110 | 97 90
For those of you that converted to a Tdi, or that have always run a Tdi, how do you keep it secure? Since I have a V8 with an ECU, I have a RFID ECU interrupt/cut-off. Since the Tdi's (300/2.5) are much more simple and don't have an ECU, how can you install something to make theft harder? As in if the thief wants your rig, he'll get it eventually, but how do you slow them down?
Old March 24th, 2006, 12:33 AM
I have a fuel shutoff. If I park in a suspect area I turn the fuel off. There is an alarm-spec TDI setup available with lots of sensors and stuff, so you could assemble a system using factory parts, but I imagine it would be somewhat expensive.
Old March 24th, 2006, 06:17 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
I'm considering to fit a de-mountable race steering wheel by OMP.
It's a weird idea which has always tempted me,and sounds effective.
If you think,unless they have a trailer,how could they drive away?
I'm interested into knowing more about the fuel cutoff as well,
if Jim wants to share
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old March 24th, 2006, 06:58 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The Tdi only needs one wire to run the engine. (other than the starter wires) The fuel solenoid on the injector pump. Its a 12 v power wire.
All you have to do is put a switch in the line and hide it somewhere in the cab or wherever. If its turned off, no fuel to the engine means it wont start and just crank over till the battery dies..
Legend in My Own Mind.
Old March 24th, 2006, 12:52 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
The hidden switch idea is a good one, I've seen that used to good success before as well. I've also seen people use brake line-locks used for drag racing as a theft deterrant as well. Removeable steering wheels are equally effective.
Is your battery also under the seat? Maybe use a boat type battery switch so you can just cut off all electrical power. those generally have a key lock on them.
-Hans
My oil line fix
My 100k stopped odometer fix
Old March 24th, 2006, 02:16 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Or just do the Getto style switch and pop the hood and pull the wire off the solenoid. I did that once...
Old March 24th, 2006, 04:34 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I've got a battery cutoff on the front of the seat box by my feet. Turn the key and pull it out = no electricity. Whenever I'm leaving the truck outside overnight that's what I do. Most folks aren't gonna figure out where the battery is anyways. Could also add a lock to the battery cover for extra protection if you're that paranoid.
edit: just like any of these: http://search.ebay.com/hella-battery-disconnect Even if you aren't using it for security they are real nice things to have if you need to kill the power in a hurry without lifting the seat.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old March 25th, 2006, 12:04 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Yeah, but then you have to walk around carrying a steering wheel and any thief with a pair of vise grips can still take your truck.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 25th, 2006, 12:30 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
I think it would quite worth it to see a thief driving a vehicle with a pair of Vise-Grips.
Old March 25th, 2006, 04:37 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
in HS a friends dad owned a shop, one of the mechanics was notorious for doing that for fun...
Old March 26th, 2006, 05:34 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Post
Hey David,although it may sound odd or unconfortable,I always carry my rucksack with me,so it would not be a big issue.
I'd much prefer to do that every time than having my current Defender stolen as well.
It did happen in 2001 already with my previous 90 and I wasn't happy at all.
My only doubt about the steering wheel is that the one I like has a 325mm. diameter,
so I guess if my instruments would disappear...?
Michele
D90 VNTdi
[O]===[O]
Old March 26th, 2006, 12:37 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Well actually, I bet carrying around a steering wheel would could help you pic up on chicks.
Chick: Whats that?
Cube: Thats my Defender steering wheel.
Chick: Whats a Defender?
Cube: Rare Land Rover, sugar buns.
Chick: Ohh, Land Rover, you want to do it?
Cube: Sure baby, sure.
Anyway, back to your steering wheel, 325mm is 13in I think. If thats the case, you'll be just fine. I have a 12in steering wheel right now and it doesn't block anything. The far Left guage is sometimes partially blocked. Not too bad.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 26th, 2006, 01:00 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
Chick: Whats that?
The rucksack would come in handy for carrying all the panties that hit the windsheild as well.
"It's not a Jeep"
Old March 26th, 2006, 01:38 PM
Rover- Girl
Guest
Posts: n/a
I have a fuel cut of switch and had LOJACK installed.
Go to www.lojack.com to find out more, It's really worth it !!( not cheap though )
I love it and its great piece of mind.
Old March 26th, 2006, 02:25 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Chick: Whats that?
LOL You kill me David...
Old March 26th, 2006, 03:07 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Chick: Whats that?
LOL!
Another prime example of poor multi-tasking on the D90 Source. Surfing porn while attempting to answer questions on the Forum.
Old March 27th, 2006, 02:28 AM
Cube II's Avatar
Cube II
Michele
1997 D90
Talking
Ditto.
Hey,thanks for the chicks hint.
I never considered such possibilities.
It could even work.
Michele
D90 VNTdi
[O]===[O]
Old March 27th, 2006, 06:17 AM
Hillbilly Raider
MANDY STRINGER
Tombraider90
I have a battery cut off key and a scary dog!!!
A not quite over the HILLBilly.
tdi
ECR New SS Exhaust Kits Coming soon TDI Too TDI Guy Misc. Chit-Chat 19 October 22nd, 2004 05:16 AM
