Am I crazy? - Defender Source
Old February 21st, 2006, 01:42 PM
Am I crazy?
OK Yeah I know Yes I am crazy!
But, I was thinking about putting a Detroit in the front diff, the front diff isn't looking so good, it's leaking quite a bit and I REALLY love the Detroit I have in the rear diff right now. What I am wondering is just how suicidal will I have to be to drive it down the road with 2 lockers? I am thinking with 2 lockers it will maybe improve breaking as it will go in a straight line rather then swerve a bit. I know I know, I am going to eat through CVs, but I figure for most stuff i can drive with the center diff open to help preserve my CVs, you know they have lasted this long with the 35s and my lead foot, so what's the locker going to do but stress them even more? , all input is well come, on topic or not :P
Old February 21st, 2006, 02:02 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
I think it is a bad idea. It will probably be very hard to steer and contol in anything but a straight line, especially in slippery conditions. I would opt for a Tru Track in the front if you have a Detroit in the rear.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 21st, 2006, 02:19 PM
Kinda what I was thinking, although it is hard to steer when the roads are slick now with the detroit in the back as it tends to plow forward unless i lock the center diff, then it helps a little. I bet it will also wear the tires weird too.
Has anyone driven with 2 lockers before?
OK, since I am a bit odd anyway, the real question is, am I going to kill myself trying to keep it on the road? Or will I just be suffering with more poor handling? Which really doesn't bother me anyway lol
Old February 21st, 2006, 03:38 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I think it would be impossible to pull into a parking space. Probably kill your power steering too. Bill at GBR says don't do it. You know the TT will work fine.
Old February 21st, 2006, 03:40 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
TT up front.
Chris von C
[/size]
Old February 21st, 2006, 03:48 PM
Yeah but a TT isn't much more then an open diff, specialy when you are lifting tires. I think i need to lurk over to pirate to see if anyone is driving around any locked SWB AWD vehicles on the street, although highly unlikely.
Old February 21st, 2006, 04:13 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Why not get a front ARB? Your going to spend the money anyway fixing all the other parts your going to break plus the body damage from the sidehill crabbing.
Old February 21st, 2006, 04:21 PM
Good point, lol well I don't fix much of the body damage other then pounding out some of the bigger dents, and I am not the biggest fan of ARb lockers, I just don't like having to rely on electrical stuff in a Rover call me crazy. But a Detriot is a good bit cheaper then an ARB.
My thought was pick up a cheapish used third with a detriot installed, swap out the front diff, if I like it I keep it, if I don't like it I can always swap back to the open diff.
Old February 21st, 2006, 04:30 PM
Scott 9835
Scott Falter
95 D90
I run ARBS front and rear. In the mud the front sucks to have locked up if you are on a side hill or making a trun. I run the rear locked most of the time and only use the front when i really have to. The detroit might be the cheap way, but you proble will like the open diff much better.
Old February 21st, 2006, 04:38 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
What gears are you running Mike..
First I wouldn't do a detroit in the front as it the halfshafts and your CV's will disintgrate before you can try to pull into any parking spot... Even the 2522 will break and such the Detroit will break when the axle/cv does..
Now for the real solution... Well you guys probably know where I stand, but think about it when was the last time you saw a Rover driving down the street make a turn at an intersection with the front locker and diff loc engaged and not break anything?
Toyota parts...
Keith
Big, Red and ... aaa Red..
Old February 21st, 2006, 05:02 PM
Toyota parts...
lol, well then i guess the front locker will have to wait for a better front axle.
Old February 21st, 2006, 05:36 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Actually, Mike, you just MIGHT kill yourself with a detroit in the front. When people say your steering will suffer, they mean it. Especially on things like loose sand, snow, wet leaves..... you know, typical New England roads between August and May.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 21st, 2006, 05:37 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
ARB is your answer. Youdon't need to run the elec. Use air comp & air switches! I am doing that in the D1 as we speak. Air comp is the only elec.
Old February 21st, 2006, 05:53 PM
Monkeyboy
Guest
Posts: n/a
There's a Detroit in the back and a TT in the front of my Disco .... there's a reason that the 109 is getting an ARB in the front to go with its Detroit ..... too much excitement in the winter!
btw, the TT has always worked great off road, I don't get the comments regards its functionality w/ a wheel lifted?
KAA
Old February 21st, 2006, 08:42 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Mike,
I know Matt Browne has set up trucks with the ARB run off a small (2LB)CO2 tank, it lasts forever since you need so little to acutate them. You could also get an engine driven compressor.
Old February 22nd, 2006, 08:18 AM
My suggestion would be to go with the ARB in the front... Being selectable, in my opinion, gives you the best of both worlds. You can try an obstical with the performance of the truck and driving ability, and if that doesn't work, then lock it up. I think it takes some of the fun out of off roading if you are locked all the time.
I have ARB's front and rear, so I am sure I am a bit biased.
BTW, I think someone is selling a set of lockers in the FS section, I think a Detroit and a TT, with 3.54 gears.
Old February 22nd, 2006, 08:41 AM
Well everyone may like their ARBs, but I am still not too keen on them. I guess i just like things plain simple and mechanical! The TT may be the way to go but I think I'll hold off until the front end is a bit more beefed up.
I'll just save up for a better front end all together.
Old February 22nd, 2006, 11:33 AM
Hans's Avatar
Hans
Hans Haase
There ya go mike, you can always save up for a Dynatrac pro-Rock 60 and one of the other lockable diff's out there such as the Ox or the Detroit E-locker.
-Hans
My oil line fix
Old February 22nd, 2006, 12:00 PM
Shane@EVS
Roverhybrids
Come on Mike just do it!
Just remember anytime you want to turn, let off the gas!
If you really want a detroit up front you can convert your tcase to part time.
Old February 22nd, 2006, 12:19 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I think TT is to much for the front CV's. I think many premature CV failures can be atributed to the TT.
ARB is the ticket.
JP
legend in my own mind
Crazy guitar Hazard Misc. Chit-Chat 1 August 7th, 2009 02:06 PM
Crazy Hybrid chris snell Misc. Chit-Chat 15 February 22nd, 2006 12:18 AM
crazy aussies lobster Misc. Chit-Chat 10 May 5th, 2005 03:07 PM
Crazy Pic and Story of Recovery Accident priest944 Misc. Chit-Chat 7 March 23rd, 2005 12:19 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
