Air suspension to fit a 110 in garage - Defender Source
Old December 27th, 2013, 12:49 PM
JeffK
Jeff Kulp
2008 RRS
This forum has been a great resource in helping me decide to take the plunge. My last hurdle is fitting a 110 in my garage. I don't have access to outdoor parking currently. My garage is 81.5" to the bottom of the door. I don't know the exact height of the vehicle yet. I was thinking I could install air suspension and lower the vehicle to get in the garage as long as it doesn't take away from the performance of the vehicle. For all I know it could improve the ride.
Any thoughts on this would be appreciated.
Jeff
Old December 27th, 2013, 12:54 PM
81.5" is 6' 9 1/2"
A stock 110 should fit. An NAS 110 would likely not fit (or it would be really really close, but a ROW should.
Old December 27th, 2013, 01:47 PM
fitting air suspension seems a lot of complication and expense ...
are you looking for a 110 ROW or NAS?
you could source slightly lower springs from somewhere like twisted ... http://www.twistedperformance.co.uk/
Old December 27th, 2013, 01:56 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Jeff
Too much hassle -- may improve the ride but will take an otherwise painless part of these vehicles and make it as finicky as the rest of the truck.
If you only have to get it in for maintenance then you can always let air out of the tires. Or do as Wolf did and set up some wheels with small tires on it just for pulling the truck into the garage.
Anyone have pics of that? Pretty funny
1986 Land Rover 110 SW
1995 Land Rover Disco (Sold)
Old December 27th, 2013, 02:29 PM
JeffK
Jeff Kulp
2008 RRS
Thanks for the quick replies.
I'm interested in an ROW 110. Outside parking is nonexistent where I live so I have to make sure before I can commit to anything. If I only need to lower it an inch or so the springs look like a good option. The air suspension would be a last resort. If it is not a reliable solution, I'll skip it.
Old December 27th, 2013, 02:30 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Thanks for the quick replies. I'm interested in an ROW 110. Outside parking is nonexistent where I live so I have to make sure before I can commit to anything. If I only need to lower it an inch or so the springs look like a good option. The air suspension would be a last resort. If it is not a reliable solution, I'll skip it.
You can always torch the springs to Lower it a little, I have seen it but never done it
Old December 27th, 2013, 02:38 PM
You shouldn't have issues as long as you don't go with a lifted truck.
Old December 27th, 2013, 02:56 PM
I imagine air suspension from a Range Rover Classic would be the easiest to fit. Not a great option in my opinion.
Old December 27th, 2013, 03:00 PM
Take a look at Himalaya ... He can probably source lowered springs.
Old December 27th, 2013, 04:38 PM
There are no off the shelf air suspension kits available. It requires custom work and the expertise to do it. It is not expensive to do, but custom parts are needed.
Old December 27th, 2013, 06:35 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Correct, I happen to have a set of air bags & mounting hardware for a 90 I put together quite a while ago. Could be made to fit a 100 with a new rear top mount/slider. Similar to the 'Ogden Air' system, all new parts & never fitted, built them & then changed direction.
Couple of pic's.....
You would need to put together the rest of the 'air kit' but it's all easily sourced from the on-line 'low rider' suppliers. I have the drawings to make a pair of front external shock mounts too as you'd need them.
Pm me if your interested in them.... there doing nothing here apart from taking up space.
Old December 27th, 2013, 06:44 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I store my stock ROW 110 in a garage that is 6'8".
Clay
Old December 27th, 2013, 07:41 PM
JeffK
Jeff Kulp
2008 RRS
Thanks for the info. I'll keep it in mind. Hopefully it doesn't come to this.
I don't trust myself doing that. I'd be the guy with the lopsided LR.
Clay
Seems like I should be fine then. At least I know what my options are and aren't if I pull the trigger.
Old December 27th, 2013, 10:32 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Check with the guys at airbagman.com They were developing kits for defenders awhile back. FWIW, I think the airbag systems will only give you a few, maybe 4ish, inches of adjustability so not sure it will truly fix your problem depending on the truck you choose
Old December 27th, 2013, 10:59 PM
landy andy, you are cray-cray but in a very good way.
Old December 29th, 2013, 01:33 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Am I the only one thinking it would be less hassle and cost to replace the door and raise the height a few inches rather than building a custom air suspension? Not that the EAS isn't a cool idea, it just seems like it is probably equal cost and a lot more hassle and potential for problems than modifying the garage it is going in.
Most importantly...It should fit as is, so as long as you don't have your heart set on a raised vehicle, you should be all set.
Old December 29th, 2013, 11:27 AM
JeffK
Jeff Kulp
2008 RRS
If I raise the opening I can't take it with me when I leave. I'll only be in this place a couple more years at the most.
Old December 29th, 2013, 11:38 AM
Garage door openings are pretty standard, they usually 7' or 8', 7' being the norm. If you adjust your current door all the way up you should be able to do the same at your next place.
Old December 29th, 2013, 01:33 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I have your standard run of the mill garage door opening on our condo.
My 110 has brand new stock springs TF AT shocks and 265/75/16 tires and I make it with just a touch of room to spare. It looks really close but there is room.
Unknown Author
716-898-8153
Old December 29th, 2013, 01:44 PM
1of40's Avatar
1of40
1of40
Tight but they fit in the standard garage config.
Clay
Wtb: Air Conditioner complete kit for 1999 defender 110 TD5 Crayfish Wanted 3 August 17th, 2013 07:08 PM
Air conditioning into a Non AC 85 110 BlackField Defender Technical Discussions 21 April 17th, 2012 05:32 PM
Does the GBR DC front shaft from D1 fit my 110? Sun Traveler Defender Technical Discussions 6 February 23rd, 2012 07:29 AM
Hannibal tent fit on a stock 110 rack pcarey Misc. Chit-Chat 8 February 4th, 2012 08:49 PM
