Air Compressors - Defender Source
Old November 21st, 2007, 04:36 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Air Compressors
What specs should I look for in an air compressor?
I need a cheap electric one for the garage. I will not use it much, just to run air tools like an impact wrench.
HP?
PSI?
Tank Size?
ect...
Thanks!
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old November 21st, 2007, 06:43 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
PSI - you want one that can run 90-125 probably.
CFM - The higher the better...this is the most important one probably. A big tank with high pressure is useless if the compressor can't fill it anywhere near as quickly as you are using it. An impact is going to need a few PSI or you are going to have to wait for the compressor after each bolt.
Tank size doesn't seriously affect price so I would get one as big as you can that fits reasonably in the space you are willing to devote to it. Remember, a big permanently mounted compressor needs a couple feet in every direction to cool properly so you can't stick it all the way in the corner.
Old November 22nd, 2007, 12:46 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
I just searched craigslist in your area. There are plenty to choose from. Direct drive and belt drive. Vertical and horizontal. Once you have one, you may wonder what you did without one and may hate yourself for going cheap and small. Belt drive will give you the most life but will put atomized oil in your line. The only disadv with this is when it comes to using your compressor for painting. An impact wrench will use 4-8 CFM. This is not a lot. When considering the tank pressure, most you will find are 125 psi, while most tools run on 90 psi. So run your tank at max pressure and buy an in-line regualtor for ~ $20 and set it at 90 psi. Some Sears air compressors get up to 225 psi. I think these are mostly their vertical, 2 stage compessors. CFM matters when you start running cutoff wheels and sanders.
A note about stages. Some compressors will boast twin cyclinder. This not the same as two-stage compressors. Twin cylinder means that the compressor simply uses two cylinders to compress the air from 14.7 psi (atmospheric) to 125 psi. Two-stage means that one cylinder takes it from 14.7 to 90 psi, discharge to the second stage, where it is pressed up to 125 psi or higher in most cases. By using two stages, the air compressor operates more efficiently and usually results in a higher CFM rating. This also produces less heat, which means less wear on the compressor and most importantly, less condensation in your tank. This is why it's important to always drain your tank when your done using it. A neat feature I've seen on newer compressors is finned discharge tubing from the compressor to the holding tank. This helps to cool the air before it gets to the tank.
If I had to buy one new, I would buy a belt driven, 30 gal, vertical compressor that runs on 120/240. Northern Tool sells one here: http://www.northerntool.com/webapp/w...1705_200311705
Vertical-Takes up less real estate in the garage
120/240-wired for 240 -> draws less line amps -> cheaper to run
wheels-can be taken to a job site
cast iron belt driven-will outlast a direct drive
I ended up buying one on ebay-60 gal, 240V-because the price was too good to be true ($150). Never regretted it. Good Luck
-Neil
Old November 23rd, 2007, 02:15 PM
Jon_Winningham
Sterling M Archer
Thanks Neil, and Andrew for all the info...
Do any of you think this one would do the job?
http://cgi.ebay.com/3-5-HP-10-GAL-AI...QQcmdZViewItem
eBay# 220174353021
compressor
In line blower for mantec raised air intake system LenB Smaller Projects 22 November 20th, 2009 08:24 PM
Quick Air Compressors 15% Off nldrvr The Vendors Loft 0 November 21st, 2008 02:22 PM
AIR COMPRESSOR Question: norros Misc. Chit-Chat 8 March 21st, 2005 03:28 PM
Air Filter Box Upgrade- Help!! alkhalifa Defender Technical Discussions 59 October 19th, 2004 04:37 AM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
