Air Compressor for home - Page 2 - Defender Source
Old June 21st, 2016, 10:38 PM
You should bite the bullet and put a full 220v sub panel out in the garage. I play an electrician on TV and would be more than happy to help put it in. Is your garage attached to the house?
Even if it isn't, a trench is not terribly hard to do.
With 220 you can run a real welder, plasma, etc, plus the two-stage compressor of your dreams. There are good ones on CL all the time. Just don't buy a 3 phase one.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old June 21st, 2016, 10:44 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
220 is easy to run like ^ he said. If you were closer I would do it for you as well.
Old June 21st, 2016, 10:46 PM
I'm dumb but I try to help How far is your clothes dryer from your garage door? Any chance you can run an extension cord out the door to the compressor whenever you need to use it?
Something like this needs the benefit of being Hard wired. Extension cords don't cut it.
As an added benefit you end up with the ability to add a charge point in the garage for an electric car.....
Do you have access to Grainger?
https://www.grainger.com/category/st...ecatalog/N-af4
Old June 21st, 2016, 11:00 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
If you go 220 add a few outlets. I have 2 in my garage but I should have added 4 or 5. I'm constantly moving plugs around.
Also, make sure the circuit is sized to your equipment or you'll trip the breaker.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old June 21st, 2016, 11:37 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I built a closet around mine and lined it with some used carpet. It's definitely more bearable. Couldn't hear yourself think when it kicked on before. Running a 220 line thru the attic from the box was not difficult
Old June 22nd, 2016, 07:32 AM
Custom closet is a great idea to reduce noise.
I would include a heavy (horsemat type heavy) rubber mat under the compressor mount (to reduce vibrations transmissted to the concrete. Take a look here as well
Room Soundproofing - How to Guide | TMsoundproofing.com
Old June 22nd, 2016, 07:54 AM
A couple things I did, semi mud flaps under the feet- horse stall mat would be better.
I threw away the oil provided with the compressor and used amsoils synthetic compressor oil. That was 20yrs ago. Never had a moments trouble and I dare say we use the old girl harder than most
Old June 22nd, 2016, 08:22 AM
87 D110 (Ruby)
Thanks guys...nothing is easy in my life it seems. The laundry is out as it doesn't back to the garage, and wouldn't be easy to patch a line to. The fuse box is as far away from the garage as it can be...also difficult to get too. As it is all finished basement.
I am gonna have to bite it and do it...I am not afraid of doing it myself - I finished a basement one time - but it is the fishing through that will be a PITA. I am gonna pay someone to do it.
Then start looking on CL like Bobeck suggests.
up for sale now.... 110v welder
Old June 22nd, 2016, 10:44 AM
cool. once you have 220 out in the garage, run some new outlets. You can do quad outlets that have two 120v circuits that share a neutral. Then if you want to change one of them later (either permanently or temporarily) to a 220v outlet all the wires are already there.
As for the 110 v 220 welders, finally got the welder hooked up that I bought a year ago form RockShow on this forum. Had to use it to weld a nut onto a broken off stud while changing the water pump on my 300tdi. Ran some test beads first on a piece of 1/4" scrap to get a feel for the machine. It definitely puts out a much nicer arc than the old 110 unit.
Present:
1987 RRC- "Chewy 2"
Past:
Old June 22nd, 2016, 11:19 AM
Needs is a strong word
230V extension cords are awesome and I have used them for years! Yes with huge 230V compressors. Lots of other NOVA folks use them as well.
Old June 22nd, 2016, 11:37 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
How are the Ingersoll Rand air compressors?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old June 22nd, 2016, 12:27 PM
yeah but it sucks to have to haul big heavy cords around each time you want to set up. Hard wired is the way to go if it is at all possible.
Present:
1987 RRC- "Chewy 2"
Past:
Old June 22nd, 2016, 12:47 PM
oilburner's Avatar
oilburner
JL
large pile of parts
Depends. The have really cheaped out on motors in the last ten years. Old ones are decent, newer ones are junk.
JL
Old June 23rd, 2016, 07:14 PM
Their rotary screw compressors are incredible for the money.
compressor
F&R ARB Air Lockers with 4.75 GBR R&P, Switches, Air Compressor, Air Line, Etc LRFlip For Sale - Parts 36 September 4th, 2014 12:35 AM
FS: ARB Air Locker 24sp in built 3rd and Puma 12v air compressor Scottg For Sale - Parts 3 May 3rd, 2012 08:18 AM
ARB Air locker Air compressor roverguy2 For Sale - Parts 4 May 27th, 2009 03:08 PM
Very dirty K&N Air Filter, FREE to a good home. themaxx For Sale - Parts 1 October 24th, 2007 01:33 PM
AC to Air compressor Mike Hippert Defender Technical Discussions 5 October 25th, 2003 10:18 AM
