Adding a Side Tank - Alternate Filler Method - Defender Source
Old October 24th, 2004, 10:05 PM
I'm installing the Euro-Spec under seat tank as an auxiallary tank during my Tdi conversion and I've wrestled with how to deal with filling it.
There is a write-uo here on D-90.com that has a neat solution using old series parts. I wanted to avoid cutting the fender and sourcing the series parts, and the different appearance of the two filler locations (stock and secondary) did not appeal to me.
Along similar lines, I could have cut another hole in the fender and used standard Euro filler parts. Again, I didnt want to cut, and the second hole would have had a squared top where the stock location i arched (anal I know) so that didnt appeal as much. Additionally, the filler tube fouls a roll cage brace running under the body.
This is what I came up with. I blanked off the filler using a hose cap from home depot (I'm assuming this will work, otherwise I'll be pulling the tank and welding a cover plate).
I then ordered a sweet aero filler cap from batinc.net (a supplier of aircraft parts and Ford Scorpio parts?), cut a hole, and installed the cap in the dead space.
Of course this requires lifting the seat base and access hatch to fill the tank, but since this is a diesel with good mileage and and auxillary tank anyway I'm not concerned. Plus I just like the cap.
Name:	Side Tank 1.jpg
ID:	1703   Click image for larger version
Name:	Side Tank 2.jpg
Name:	Side Tank 3.jpg
Old October 24th, 2004, 10:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Great idea, but good luck keeping the smell of Diesel out of the cab.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 24th, 2004, 10:46 PM
Ah just like a series I.
Just to check but does a diesel nosel work with that filler . . . .
Old October 25th, 2004, 03:49 AM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Very neat solution. I can get 700 miles range with my twin tank set-up.
Mike Hammond
Old October 25th, 2004, 07:01 AM
Thanks guys, two points-
1) I'll be using bio diesel almost exclusively so the smell isnt that big a deal (but I hadnt thought of that, though, I'll have to investigate the best seal I can for the hatch)
2) The filler hole is 1.75 inches across, I'm pretty sure a nozzle will go in there...
Old October 25th, 2004, 12:21 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Jim, if you had room, you could have welded a filler pipe on top of the tank, and routed it out to the back wheel well. Just leave the pipe stuck up as high as you can under the bed to make sure it doesn't get hit. This is the way the aux. tank was on the defender I sold a couple of months ago. Then you don't have to worry about dropping smelly diesel inside the truck.
How in the world have I spent this much money and still don't have a running vehicle?
Old October 25th, 2004, 12:29 PM
Thats true, and if this method sux, I'll try that next.
Best method to clean a gas tank devinchi Defender Technical Discussions 16 April 10th, 2008 05:50 PM
Rimmer Supercharger, complete. Also side fuel tank. Tom Fitzgerald For Sale - Parts 14 December 12th, 2005 08:09 PM
FAO:Buckon37 or any air tank user... Cube II Defender Technical Discussions 9 July 4th, 2005 04:05 AM
Aux tank and LR winch bumper Jase For Sale - Parts 10 July 1st, 2005 06:38 PM
Side Sattle tank for Sale Buckon37s For Sale - Parts 5 December 22nd, 2003 03:41 PM
