Accessory wiring - Defender Source
Old August 7th, 2015, 01:49 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Accessory wiring
I'm about to install a number of accessories onto a D90, and want to run multiple wires inside a durable outer sleeve, similar to trailer wiring.
What I'm looking for is options for junctions, ie: if I need to open the harness at some point to connect a light, what could I use instead of heat shrink or electrical tape? I want to make it look nicer than just taped-up. Likely to be 18/3 or 16/4, but also smaller wires for the low draw LED stuff.
Any suggestions?
Email is
Same place, new dogs.
Old August 7th, 2015, 02:36 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
There are 'T' junctions for the corrugated split wiring loom. You can get them that have a smaller size branch if you're only adding one or two wires somewhere in the run. I'm not clear if that's the sort of thing you're looking for or not.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old August 7th, 2015, 02:46 PM
asetliff's Avatar
asetliff
Adam Setliff
2A 109 Four Door 07 RRSC
Techflex split loom is what your looking for.
http://m.ebay.com/sch/i.html?_nkw=te...d=&sqp=tech+fl
That's the mobile phone link. Try removing the m in front of eBay.
Here's what I think your requesting. http://m.ebay.com/itm/1-8-SPLIT-BRAI...707?nav=SEARCH
Old August 7th, 2015, 03:05 PM
Roverlab
Trevor Griffiths
Wire Loom Tees
This is what I had in mind at junctions; haven't yet found the specs for the od on something like 18/3 or 16/4
Email is
Old August 7th, 2015, 03:53 PM
Roverlab
Trevor Griffiths
Found what I was looking for on the Waytek site! I've used them plenty in the past, but hadn't realised their on-line catalog has a lot more coverage than the website. C'est la vie.
Email is
Old August 7th, 2015, 04:15 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
I'm a huge fan of braided sleeving. I never knew anyone made a split-loom braided sleeve. Thanks, asetliff. I think braided sleeving provides the best look and best wear protection with the least hassle. It's quick to install. To cut it, don't use scissors. Stretch a length of steel safety wire between two solid, non-flammable objects and heat it with a MAPP torch, then use it to melt the sleeve.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old August 7th, 2015, 04:40 PM
Roverlab
Trevor Griffiths
Rocky: You're welcome!
Email is
ac, wiring
Hot New Accessory - Perfect! JimC Misc. Chit-Chat 19 July 24th, 2005 10:49 AM
SuperWinch Accessory Kit danielj For Sale - Parts 3 May 9th, 2005 10:36 AM
Spanish accessory shops in Spain? Davis Misc. Chit-Chat 0 April 25th, 2005 06:16 PM
So, if you could get any accessory you wanted.... Hans Misc. Chit-Chat 18 February 17th, 2005 09:47 AM
The right accessory - it can not be so hard paulb Defender Technical Discussions 5 February 8th, 2005 02:41 PM
