AC transplant from another vehicle (non rover) - Defender Source
Old August 11th, 2014, 11:37 AM
corrumpu
chris b
1995/RRC SWB
I looked around the net but couldn't really find my answer.
I see others have talked in the past about rear AC units for a defender 110. There are several solutions with varying degrees of cleanliness for install.
What are the obstacles with using a rear AC from a more common vehicle like a Honda Odyssey (or insert any other rear ac equipped common vehicle) There are a shit ton of these on the road and subsequently alot in the you pull it lots. Also toyota/honda air is pretty fscking cold!
--chris
Old August 11th, 2014, 11:50 AM
--chris
AC rear or front is just a matter of ducting cold air to where you want it ... the issue is the generation of that cold air ... that means compressor, condenser, fans etc. This is going to get very complex very quickly.
The simplest solution may be to install a capture hose in the front system with a fan that pulls / pushes the air to the rear via flat insulated ducts.
This is how NYC taxi's solve the problem.
Old August 11th, 2014, 11:53 AM
AC units in Rovers are made from commonly available components. The things that are hard to come by are the crappy blow molded ABS plastic housings.
Compressor is the venerable Sanden, and you can put in whatever you can fit as far as the evaporator and condenser goes. You just add a receiver/dryer and a control switch and you're off to the meat locker
Old August 11th, 2014, 12:25 PM
phoenix37's Avatar
phoenix37
john
Any of these universal units fit under the dash?
http://www.oldairproducts.com/catalo...120132099.html
Old August 11th, 2014, 12:58 PM
Elite was the company who one made the rear units. Per their website they do "customs" systems. Perhaps they would make you one ?
http://www.elitekl.co.uk/land-rover-...itioning-kits/
ac
Motor Mounts: 200TDI Transplant in 110 rdavisinva Defender Technical Discussions 84 October 8th, 2017 10:47 PM
300tdi transplant willtillery For Sale - Parts 8 November 1st, 2011 12:10 PM
Help needed for non starting, non fuel pumping rover sherpamike Defender Technical Discussions 24 July 28th, 2009 11:49 AM
Body Transplant ajh Defender Technical Discussions 2 November 23rd, 2007 11:41 PM
another wierd vehicle 1000kva Misc. Chit-Chat 3 December 18th, 2006 01:53 PM
