A/C loses charge x 2 - Defender Source
Join the Defender Source Community Today
Old August 3rd, 2016, 12:23 PM
ymc226
Lawrence
1995 D90 SW NAS
Have a 95 NAS D90 SW with a dealer installed A/C near the time of purchase by original owner. I bought the truck 2 years ago when the PO stated he recently had the A/C charged. A/C worked for a few weeks then stopped blowing cold air. I had it charged again at my local garage and a similar pattern recurred.
Do I need to take it to a Land Rover dealer or is the system easy enough for a regular garage to troubleshoot? BTW, my local LR dealer (Princeton) lost its Defender mechanic so I not sure they have anyone experienced in anything except late model Rovers.
Old August 3rd, 2016, 12:36 PM
You don't need a defender mechanic. You need to put dye in the system (or have a mechanic do it who's competent with A/C's) when you charge it and track the leak. Btw if you see a beach runner 110 down there, wave - it's my friend.
Old August 3rd, 2016, 02:00 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Joshua was on the money.
After you find the leak and fix it, it would not be a bad idea to install a new dryer and expansion valve.
I found the expansion valve on Rock Auto, but the original dryer was tough, so I put in a generic one with a low pressure switch only.
BTW, we have this same Diavia unit in a 1983 110 and it is so cold that if I don't run it on low, it is just too cold unless it's the hottest part of the day and then it gets switched 1 setting below high.
RDavisinVA
Old August 3rd, 2016, 02:42 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
What I've done is bought a can of refrigerant at the auto parts store. I got one with the hose and gauge included. Read and follow the instructions or watch a video. It has worked twice on my 90 over the past 5 years now and my son and I did his Disco1 this summer.
Old August 3rd, 2016, 03:37 PM
ymc226
Lawrence
1995 D90 SW NAS
Thanks all. I have held off on driving these past 2 weeks due to the 90+ temps. I haven't seen a beach runner in Princeton ever. What color is it?
Rob, what is the dryer and expansion valve you refer to? I'd like to mention that to whomever I take the truck to. Would a radiator shop have more expertise in A/C units? My patient manages a radiator shop so I would trust him to do the work.
1of40, I might go this way . . . I'll post a picture of what I think is the charging port of my Defender later to make sure I pick the right one.
Old August 3rd, 2016, 03:59 PM
1of40's Avatar
1of40
1of40
It's tough to get it wrong as the sizes of the ports are different. On his D1 there is an H for the high point and L for the lower point. The lower point is what you want. the instructions should tell you to test the pressure the system is under before adding coolant. That's key and also not over charging. Too much coolant will not allow the circulation the be efficient.
Old August 3rd, 2016, 07:04 PM
ezzzzzzz
Mark Garrenton
'71 IIA 88 LS1 coiler, '84 110, +++
The port sizes are different as I recall. Basically, you want to attach to the larger of the two aluminum AC lines. The fitting, on the larger aluminum line, will be between the bulkhead and the AC compressor. The other smaller aluminum line runs from compressor to condenser core to dryer to bulkhead. If you don't add a UV dye to determine the leak location you're wasting your time and money. It is probably a leaking fitting on a flex hose. Look at the fittings for a sign of oily residue. The UV dye will confirm the leak. If you have to replace a hose the dryer should be replaced at that time. The dryer pulls any moisture out of the refrigerant flow that would damage seals and the compressor.
Retirement is great, I haven't missed a day yet!
Old September 11th, 2016, 09:38 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
For the Diavia unit:
Expansion valve:
https://www.rockauto.com/en/moreinfo...=1433885&jsn=1
Dryer:
https://www.rockauto.com/en/moreinfo...=1187074&jsn=1
RDavisinVA
Old September 11th, 2016, 12:14 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I have been through this for almost two years or so with my system. My original problem was the expansion valve. Replaced that and put a new dryer in. Then I had a hose issue. Got a new one made. Turns out they messed up the crimp on the hose. Had to get another one made. The issue for me is in the process to discover leaks. Freon costs money and in order to find a leak they have to fill it up with freon with dye to find the leak. Then once found you have to remove freon then repair leak and pay for more freon. It can get expensive. I was able to luckily find a shop that uses co2 to energize the system and listen for leaks. Worked perfect and saved me some dough. Might be worth looking into.
ac
Engine loses power at 2500 rpms Hazard Defender Technical Discussions 17 October 15th, 2010 03:57 PM
Defender vs Jet. Jet loses? Trigger Misc. Chit-Chat 1 September 12th, 2008 07:37 PM
300 tdi with a/c loses power discotdi Defender Technical Discussions 10 July 17th, 2008 09:18 AM
Wiring questions for split charge system aclarke Defender Technical Discussions 5 April 23rd, 2007 03:39 PM
To charge or not to charge . . . Bozman Defender Technical Discussions 2 March 5th, 2007 09:29 AM
