97 Defender 90 Questions - Page 2 - Defender Source
Old June 16th, 2014, 02:06 PM
aquatiger's Avatar
aquatiger
S
none
Yeah, I talked to the guy up at Badger for a while this morning. He said it's about a 4 month wait for a top. The guys at Rovers North have a twillfast top that looks similar, but I bet it isn't a Badger in quality:
http://www.roversnorth.com/ProductDe...T02&type=0&eq=
No offense Keith, but that top doesn't look fine. It needs a new top. If you'll let me hose it off with that top on and there isn't significant water inside, then I'll buy it for your price Does this one still have the surrey top, or no longer?
I ran into a guy right outside my office who was driving a beautiful Monza red 97 defender. I offered him cash right there for it. He bought it from, guess who? Copley. He wouldn't sell. Rolf has a 97 beluga black going up for sale soon. I'll post some pics and see what you guys think. So we'll see.
Anyway, the search goes on...
Old June 16th, 2014, 02:51 PM
d90boy's Avatar
d90boy
keith humphreys
aka: Mr Fancy Pants
come on up..... but you have to hose every other truck off to. all soft-top leak. =)
there is also a little less of a gap now-a-days since i added the vertical bars that go in the sleeve - but there is still a small gap.
Old June 16th, 2014, 10:45 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
a four month wait?
Old June 18th, 2014, 09:18 AM
aquatiger's Avatar
aquatiger
S
none
Originally Posted by Birdman View Post
a four month wait?
Yeah, I talked to him on the phone for a while. I thought from other people that it's a much longer wait, but that's what he told me. Maybe that's just wishful thinking on everyone's part...
Old June 18th, 2014, 10:52 AM
The "Guy at Badger" is Chris Laws. He's the Boss, secretary, seamstress, shipping department, accounts and billing.
Old June 18th, 2014, 12:54 PM
Willh's Avatar
Willh
Will Hedrick
Use to own NAS #96, #1778, & #1008
No offense Keith, but that top doesn't look fine. It needs a new top. If you'll let me hose it off with that top on and there isn't significant water inside, then I'll buy it for your price Does this one still have the surrey top, or no longer? I ran into a guy right outside my office who was driving a beautiful Monza red 97 defender. I offered him cash right there for it. He bought it from, guess who? Copley. He wouldn't sell. Rolf has a 97 beluga black going up for sale soon. I'll post some pics and see what you guys think. So we'll see. Anyway, the search goes on... Thanks
Originally Posted by d90boy View Post
come on up..... but you have to hose every other truck off to. all soft-top leak. =) there is also a little less of a gap now-a-days since i added the vertical bars that go in the sleeve - but there is still a small gap.
I've got to back Keith up here, for a factory Bestop, the soft top does indeed look to be in good shape. Unfortunately, that's the way it was from the factory in the 90's. The gap between the doors was a flaw in the design that Bestop later tried to cure with support bars. But, even with the additional bracing, they all leak, even when new. You can still buy a new Bestop and it will do the same thing right out if the box!
But, I guess it's all based on perspective. Keith and I have been around Defenders a long time so what's normal to us sometimes comes across as abnormal to someone that's just learning about the vehicles. As a prospective first time Defender owner, you should prepare yourself for the truck's many idiosyncrasies. Hell, even a Defender station wagon, which has a full hardtop, leaks around the corner of the doors.
But, if getting getting a little wet is not your cup of tea, then it sounds to me like you're looking at buying the wrong vehicle......
Please feel free to visit my website at:
Willh is the F'n man! Defender of the Defenders! - Overlander
Old June 18th, 2014, 02:10 PM
aquatiger's Avatar
aquatiger
S
none
Thanks for the input. I agree that these cars have their issues. There were a few more issues that precluded me from buying it, not related to the cost. I definitely have no concern about getting wet. But if a top doesn't even tuck in around one rear corner, and there are visible gaps that you can fit your hand through, then it's not even average.
I'm sure you've seen worse in your experience. But even Keith has 2 others for sale right now that don't have that problem...
All that being said, you guys know these trucks way better than I do. So I could be wrong. I guess it's just my opinion then.
Old June 18th, 2014, 03:12 PM
Willh's Avatar
Willh
Will Hedrick
This sounds like a problem with the fitting, more than a problem with the top.
There is no give in the roll cage, so the top needs to be hot (literally) and pliable in order for it to achieve a proper fitting on the truck. Best way to accomplish that is to set the top out in direct sunlight for a few hours so the material can expand. If it was put on the truck without doing this, then the top will not fit properly.
An alternative solution to the problem you're describing is to take a hair dryer or heat gun to the effected area, along with a little "elbow grease". With a little expansion of the material, the top should fit in around the rear corner. As for the gaps, I think Keith already said they've added the B-pillar support bars to keep the top from bowing behind the doors. A little heat and adjustment on those portions of the top should achieve a tighter more acceptable fit.
Bear in mind though, after all this, it's still going to leak.
That being said, I can understand if there are other concerns. I was only addressing the one issue that I was aware of.
At any rate, best of luck in your search!
90, 97, defender, defender 90
My First Defender Questions IvanKV Defender Technical Discussions 150 November 30th, 2013 07:50 AM
Defender Registry Questions Andy R Misc. Chit-Chat 39 February 16th, 2012 08:50 PM
TD5 bulkhead into NAS defender questions evilfij Defender Technical Discussions 15 April 15th, 2010 03:13 PM
Questions for you Diesel Defender owners Grover Defender Technical Discussions 19 August 31st, 2007 05:41 PM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
