95SWB, clicking relay... - Defender Source
Old October 16th, 2014, 10:51 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
Engine running, when I move the key around in the ignition of my 95SWB, a relay or something behind the instrument cluster clicks. Occasionally clicks on bumpy roads too. Is it a bad relay or bad ignition switch?
Old October 16th, 2014, 11:16 AM
sloanfiske's Avatar
sloanfiske
Anthony Nelson
My 94 did the same thing. Just a click at startup and then when the brake pump clicks on. Is the click followed by the hum of the pump? Could be the ABS pump.
Never an issue for me.
Old October 16th, 2014, 11:25 AM
RX6RCROL's Avatar
RX6RCROL
Matthew Hedrick
1994 D-90 #646
I have that click too. This click is somehow related to the key in the ignition. With ignition on...push the key-click, pull-click, twist-click, hit bumps-rapid clicking, hold key firmly over bumps-clicking stops.
Old October 16th, 2014, 07:08 PM
Lemonhead
TB
1997 D90 SW
I've had it intermittently on my '97. And it doesn't stop even when truck turned off. Have to start truck again for it to stop. Read somewhere that it may be the alarm ECU (green box on bulkhead behind cluster). I've seen it - but I don't have an alarm.
Oops - just realized we weren't talking about a 90.
Can only edit post - not delete it.
1997 A/C relay clicking JKC Defender Technical Discussions 6 September 21st, 2013 07:21 AM
Relay clicking, engine stuttering.... help! revtor Defender Technical Discussions 9 December 6th, 2007 08:23 PM
Clicking noise from behind IP - 97 D90 Saito Defender Technical Discussions 3 March 28th, 2006 11:17 AM
Transmission clicking? oldscratchggf Defender Technical Discussions 1 June 14th, 2005 06:42 AM
Clicking from the dash? greg_sikes Defender Technical Discussions 14 November 9th, 2003 07:31 PM
