94 d 90 # 2699 - Defender Source
Old May 5th, 2013, 11:16 PM
jmorton
Jon
94 d 90 # 2699
Hey All,
I have wanted a D90 for a long time but have never actually pulled the trigger. The other day I passed a 94 Red D 90 # 2699 for sale. The truck has 108k miles and they are asking $27k. It has the hard top and a really rough shape soft top. Does any one have history on this particular vehicle? The condition overall is pretty good, I didn't see any rust on a quick inspection. The biggest issue I saw is that the red paint is pretty faded.
What else do I need to be thinking about?
Thanks!
------ Follow up post added May 5th, 2013 10:20 PM ------
Old May 5th, 2013, 11:21 PM
jmorton
Jon
ID:	71601   Click image for larger version
Old May 5th, 2013, 11:29 PM
bjf's Avatar
bjf
barry f
94 ST #395
So many issues not sure where to start.
Flares cut.
Multicolor hard top.
Diamond plate literally everywhere.
Holes cut in hood.
Run away.
You sure it is a 94? It has 95 lights front and rear.
Old May 6th, 2013, 12:03 AM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Flares cut.
Holes cut in hood.
Run away.
Yeah, for $27k you should be able to find something nicer than that, might have to look around outside PNW, i know used SUV's get expensive up there.
Old May 6th, 2013, 06:19 AM
Here is the listing from LRFAQ
SALDV2282SA965062 '95 #2699 Portofino Red ARB Air lockers (F&R), PIAA 1200's, Hella 2000 (4), OEM wrap around brush bar, GPS, 285/75 BFG MT tires, CB, British Pacific front skid plate, Proximity alarm, OEM nerf bars, Optima battery
Has they removed that gear. Owner must be cheap. Masking tape to create a for sale sign?
Old May 6th, 2013, 06:43 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Before you go running for the hills, what are you looking for out of this truck. If the mods listed above are included and you are looking for a truck that will see a mix of asphalt and dirt then it may not be as bad you think. However, if you are looking for a beach or mall cruiser the I agree you should look elsewhere. That being said, there are some things (as others pointed out) that you should make sure you have an understanding of why the PO did them. The diamond plate for example, was it installed for protection, looks or because there is a bunch of rust and dents behind it!
Old May 6th, 2013, 08:32 AM
Kelbo's Avatar
Kelbo
Kelly
'86 110
What's with the holes in the hood?
Ha
Kelbo
'86 110
Former Rigs:
'94 D 90 ST
'84 D 130 Hi-Cap
Old May 6th, 2013, 08:43 AM
Ha
for extra cooling .... was quite a common mod .... personally i'd prefer to fix the cooling issues ...
Old May 6th, 2013, 08:51 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Ha
Or as Homer Simpson would say, they are speed holes:
Semper Fi!
Old May 6th, 2013, 08:55 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
For 27 you should be able to get a real nice 94 or 95.
Holes in the hood would make me think that it had or had overheating issues in the past.
If you wanted to remove the plate on it that would cost big $$$$ to do a proper job and who knows what you will find under there when you pull it off. (Doubt rust since it is alum under there but maybe dents)
Hardtop is not such a deal killler for me, you would always have the sides and liftgate painted to match the red on the truck and it would look better or have the top sprayed black.
This is just the stuff we can see and with the bad choices that have been made on the outside I would hate to see what was done in other areas.
Old May 6th, 2013, 04:34 PM
jmorton
Jon
Thanks everyone. You all picked up on some key issues that I didn't when I spent 10 min looking over the truck.
Ill keep looking.
Old May 6th, 2013, 05:13 PM
WD90's Avatar
WD90
Dan
1995 NAS Defender 90
Glad I saw the diamond plating on the rear panels. I was thinking about doing that on mine, but looks like Fido's ass to me. The cut down flares look horrible too...
Seems overpriced to me since he hacked it up so much.
Old May 20th, 2013, 04:23 PM
Originally Posted by jmorton View Post
Hey All,
Thanks!
Now on eBay. Currently bid up to $17,100. No mention of why basically the entire truck has been covered in diamond plate aside from him saying it was powdercoated black...
bettermango ( Feedback Score Of 20)
SALDV2282SA965062
http://cgi.ebay.com/ebaymotors/1995-...bc0f4b15#v4-41
I have owned this truck for the past 10 years and loved her dearly. It has 108,000 miles and has been kept in a garage. I have never done any serious off roading in it. Lots of camping and some dirt road access. It has normal wear and tear of a 17+ year old truck - but no rotting or rusting anywhere. some TLC needed at seat corners and around edges of seat bases. Back seat is perfect. It spent most of its years in San Diego and Portland for the last 2. It was serviced by The Rover Group in San Diego - since has changed name to The British Garage. As you can tell by the photos all diamond plating has been powder coated black. The factory LR wheels also have been powder coated black. There is a bimini top included with purchase, also the tonneau cover (never used) in addition to the POE fiberglass hardtop and happily can throw in the soft top i used. It has no windows and some patches. In addition to regular 3000 mile oil changes and factory recommended fluids here is a list of what has been done:
April 2010
Rebuild and reseal transfer case
Headgasket and Valve job
replaced water pump, alt, and power steering belts
replaced battery terminals and wiring
Had POE Fiberglass roof - rhino lined
replaced both cats
replaced window squirter
April 2009
Replaced steering ball joints and pitman arm
Replaced speed transducer
Replace cable from T-Box to transducer
Replaced Idle Air control valve
Replaced motor mounts
Replaced rear drive U Joints
Rebuilt Drive Shaft
Diff/Trans oil replacement
Replace all Brake pads and rotors
Repack wheel bearings
February 2007
Replaced Ignition coil
November 2004
Replaced Tuffy center console
I have the detailed service records for all described.
This has been a great vehicle for me over the years and now its time for someone else to enjoy.
I reserve the right to end the auction early as I have it for sale locally.
Name:	2699 diamond plate special 1.jpg
ID:	72685   Click image for larger version
Name:	2699 diamond plate special 2.jpg
Name:	2699 diamond plate special 3.jpg
ID:	72687   Click image for larger version
Name:	2699 diamond plate special 4.jpg
Name:	2699 diamond plate special 5.jpg
Old December 17th, 2014, 01:23 AM
Soon2Be1
Brandon Chapelo
Update for #2699
So this is my first post. I joined to find more about the vehicles as I am very interested in getting a Defender. I'll search around and I am sure I will find good info.
Here is an update for 2699.
The below link is to the dealers site selling the vehicle. My concerns are the vehicle has been painted and "has a newly built engine" but with information I found on this forum this may be pretty beat and concerns are about the mileage. Of the guy was asking 27k and the new owner bought and just painted, why is the odometer still at 108?
http://www.landmarkmotors.com/used-c...Model_~Year_/1
Any thought? Worth even $40k?
Thanks!
Old December 17th, 2014, 01:59 AM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
I wouldn't offer $20k for it. Look at that picture of the door hinge. They just painted over everything and you can see a little red showing through in the corner. Horrible. That's not a restoration. It's a cover up. They could have just buffed it. At least then it'd be original.
Old December 17th, 2014, 02:02 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Holy 5-bar Batman! Had to be said. Sorry! But in all seriousness, I may be one of the least qualified to weigh in on quality and potential real value, but as an owner for 6 yrs. I am at least qualified to say this; there is way too 5-bar on that truck, some of which serves no purpose other than concealment. The rivets are easy to drill out and replace for the purpose of rust/rot inspection. Do it if you're seriously considering buying it. Wings, rear quarter panels, and the rocker are all that you would normally see. Maybe the previous owner (PO) was afraid of gas station attendant spilling on his paint and over-clad the fuel area. Then he matches the opposite side for symmetry. But the tailgate and back panel are suspicious and I can guarantee you that if you pull one section of 5-bar it should be the panels above the rocker. Door bottoms are notorious for rust and I have never seen a single defender with 5-bar above the rocker. I can't believe that it was installed to armor the door against opening into other objects or dings. Also, the seller is giving you pretty pictures. Not money shots. And it is a pretty truck! Nice paint job. You'll learn that mileage isn't as important as condition and maintenance as long as it's not a sub 50k mile truck. These "money shots" (as we refer to them) are undercarriage pics of the rear crossmember, outriggers, door sills, frame... Hell, anything that isn't black under the truck. Research this site for more pointers. These guys are amazing. Both knowledgable and extremely helpful to honest people, owners, and potential owners. If you've got the Defender bug, you are welcome here. Good luck with everything. Just my two cents.
Old December 17th, 2014, 02:13 AM
cwilder's Avatar
cwilder
Chad
2012 110 Black
I'd pass on that one, Wow!
_________________________________
2016 Range Rover TD6
2013 Raptor F150 SVT
1997 D-90 #1867 (sold) :(
2012 Black 110 :) In OZ still
2011 LR4 "Metropolis" (sold) :(
2011 Raptor F150 SVT (sold) :(
2007 Shelby GT500 (sold)
2007 LR3 (sold)
2006 RRS (sold)
Old December 17th, 2014, 02:14 AM
Chip's Avatar
Chip
Andrew
Probably lots of galvanic corrosion.
Old December 17th, 2014, 02:22 AM
D90Overkill
David Frank
1995 ST #2615
Maybe they flatbeded it to the paint shop. Just get documents verifying mileage since the last owner and the engine build, drill the rivets out for inspection (bring a rivet gun and an assortment of aluminum rivets for repairs), and if everything checks out, offer them what you think is fair. Someone spent a lot of money gussying it up. I though the seat boxes were rhino lined (another potential cover up) but I see now that the tunnel cover has a seam and it looks like some kind of fabric. All of that is usually rubber. Either way, it can be lifted for inspection. Footwells (kick panels) are key. I'd take the under on $30k
Old December 17th, 2014, 07:50 AM
It's good to see when potential buyers do a little research and can find our conversations here. May save him from making a purchasing mistake, or paying far too much.
Now, onto value. I wouldn't pay $48k for that truck, I wouldn't pay $40k, I wouldn't pay $30k for it either - some people in your area may pay $30k or a little north of that but I don't believe many will be lining up for it with all of that 5 bar plating in spaces I've never seen before. That paint job doesn't add any value either in my opinion. They'll have to be lucky to find someone in order to sell it at their price, and may use that "paint job" as an excuse for how much (little) they've put into the vehicle.
Complete EFI from 94 NAS 90 wantone For Sale - Parts 2 April 12th, 2013 01:00 PM
Need 4 fender flares for 94 D 90 Froggyhonkey For Sale - Vehicles 3 October 21st, 2011 03:30 PM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
94 defender 90 washington pacificwildfire The Flea Market 0 April 4th, 2011 09:50 PM
94 Defender 90 cranks but won't start Charles LF Defender Technical Discussions 6 September 9th, 2009 02:43 PM
