8274 rebuild - Page 3 - Defender Source
Old March 9th, 2012, 09:45 AM
galen216's Avatar
galen216
Galen Lentz
'98 D1
I think I used 30 weight. I have never changed the oil despite putting in a drain plug. I used a 1/4 npt drain plug. Can't remember if I borrowed the tap or bought one. McMaster Carr sells the taps cheap and the drain plug. I'll try to take a picture this weekend.
'98 D1
Old March 9th, 2012, 01:19 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Tony, I can double check but pretty sure I have an 1/4" NPT tap if you need to borrow it
Old March 9th, 2012, 01:37 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Thanks, Jeff, I may take you up on that. Picked up a fresh set of square nuts and socket head screws to hold the halves together along with some 30wt. And a new set of circlip pliers. At this point I think all that's left is to source some welding cable.
Old March 9th, 2012, 01:52 PM
galen216's Avatar
galen216
Galen Lentz
'98 D1
Use stainless SHCS's. Mine rusted in very short order, they collect water in the top of the head. Unless you have a garage then no worry for you.
------ Follow up post added March 9th, 2012 01:53 PM ------
It may have been a 1/8 NPT too now that I think about it. Really doesn't matter as long as the plug has a good seal.
'98 D1
Old March 9th, 2012, 01:59 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Good idea(s), Galen. The winch came with a cover, but I may just put some silicon in/on the bolts to be safe.
Old March 9th, 2012, 02:02 PM
Mine should be home Sunday if you want to compare drain hole locations, and I have a tap and die set as well.
Originally Posted by pendy
I'm here for the D's
Old March 9th, 2012, 02:06 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I also believe I have an 1/8" NPT tap but will double check. and yes, I will bring Galpin's pile of parts with me on Sunday if you are around...whenever he becomes less of a deadbeat and decides to install this thing somewhere I will help him paint it!
Abrooks's Avatar
Abrooks
Tony Brooks
If I can make it out there (if I can, it'll likely be with my son), I'll definatly bring the winch, thanks.
That said, I'm about the last person you need to help you install an overhead beam . . .
Old March 9th, 2012, 03:39 PM
Abrooks's Avatar
Abrooks
Tony Brooks
OK, I'll be there with 3 year old in hand.
Old March 9th, 2012, 03:41 PM
Awesome. I'll have Donna entertain you while the young man lends us a hand.
Old March 9th, 2012, 03:42 PM
Abrooks's Avatar
Abrooks
Tony Brooks
That's likely best for everyone involved.
Old March 9th, 2012, 04:24 PM
I believe he's going to have the help of a young Lavendar as well
Old March 10th, 2012, 12:46 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Long but successful night. Winch is assembled, mounted on the arb and the arb is half installed. I remembered as we were dropping it on to the frame rails that you're really supposed to grind off the extraneous chunks of frame to install an arb, so now we know what I'll be doing tomorrow. Also, the steering guard shared space with bumper, look for it in the classifieds soon.
It's a shame that after all the work on the winch it's hidden behind The Steel Curtain of the arb.
Next: grind the chassis into compliance, source welding cable to wire the winch, source synthetic rope, and go find a shopping mall planter to self-recover from.
ID:	48811   Click image for larger version
ID:	48813   Click image for larger version
ID:	48815   Click image for larger version
Old March 10th, 2012, 11:06 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Nice work.
Old March 29th, 2012, 11:04 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Everything is mounted, wiring is done save running the cable to the battery, runs perfectly and just need to tension the rope and spool it in all the way. Couldn't be happier both with the finished product and the learning experience.
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
where to find rebuild manual for 4.0L? Chris Cox Defender Technical Discussions 0 January 27th, 2004 09:36 PM
