300Tdi advice for long drive - Defender Source
Old April 5th, 2010, 02:20 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
So, having bought a 1984 D-90 in the UK (that seems to mostly be ~1996 parts including the 300 Tdi), importing it (thanks again Doug!), and shaking out some very minor issues, I am about to drive it from upstate NY to Seattle, WA in a couple of weeks. Apart from the obvious- check and address any leaks, change out all fluids, what should I have done or looked into before setting out? I've actually done the drive 3 times with nothing more serious than a wiper arm loosening up- twice in my 1990 Pathfinder (Calmini lift, Thorley headers).
Planning on going mostly I-70 this time around so I can make a small detour through Moab (any cool trails I should check out there?).
Thanks for any and all advice!!
-Gardner
ID:	26343   Click image for larger version
ID:	26345   Click image for larger version
Old April 5th, 2010, 02:49 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
when was the last time the timing belt was serviced? I did my (200tdi) prior to driving Seatle to SF - Importred through Julian and Doug. Julian recommended a service as history was unknown. Glad I did - the old one was a mess.
Crawl under and check U-joints also. My lower front was toast (no needle bearing left) - That would have been unpleasant.
Old April 5th, 2010, 02:52 PM
Gore Ranger's Avatar
Gore Ranger
Jeff
1989 RRC
I'd suggest Fins N' Things and Poison Spider. You probably wont break any thing on those, and they're both fun and scenic.
Old April 5th, 2010, 03:32 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
other than the timing belt there's not much tdi specific that can go wrong... maybe make sure you have a pair of ear-plugs
makes the drive so much more pleasant
Old April 5th, 2010, 03:37 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Just make sure you have phone numbers for relevant parts places, maybe a manual on DVD to help you change something like an injector or lift pump.
I would put some new filters on including the fluid changes.
Old April 5th, 2010, 07:08 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
Don't know how complicated a timing belt replacement is on these. Anyone know if there's a good independent LR shop in the Albany or preferably Saratoga, NY area?
Old April 5th, 2010, 07:49 PM
lrnasd90's Avatar
lrnasd90
J. Landers
1983 110 LHD Galvanized Everything
Don't get in a hurry. It is going to be a long drive. If you don't have too much stuff in the truck you should not have too much trouble with the hills, but if you have a load....get ready to ride the shoulder.
93 NAS D110 #137 Sold
1-94 NAS D90 #702 Sold
2-94 NAS D90s (#1112, #1586)tdi Sold
95 NAS D90 #262 Sold
1-97 NAS D90 #642 Sold
2-97 NAS D90s LE (#82,#222)Sold
110 Crew Cab Td5 Sold
Hybrid Series 3 Sold
3-D1 Sold
1- D2 Sold
4- RRC Sold
83 110 5dr Diesel (current)
97 Disco XD tdi (current)
I can quit at any time I am not an addict!!
Old April 5th, 2010, 08:38 PM
I would post your route and get some Member's contact info... That way if you have an issue, you have a friend to help.
Old April 5th, 2010, 09:22 PM
They are a bit slow to sign you up but you should join the birmabright brotherhood. Or call one of us who are already members if you end up needing help.
http://www.birmabrightbrotherhood.org/
Old April 6th, 2010, 10:58 PM
Gardner's Avatar
Gardner
Gardner Congdon
'84 RHD D90 300Tdi
Thanks guys. Did some digging and the timing belt was replasced 20k miles ago. Fluids and filters quite recent. My brother is still shaking it down a bit, so we'll see if anything else turns up. Sent an email to the Birmabright Brotherhood- many thanks for that reference! I'll post the intended route in a couple of days.
Thanks again!!
-Gadner
Old April 6th, 2010, 11:40 PM
having driven the truck and given it a quick once over I think its ready to roll.
Old April 7th, 2010, 06:27 AM
draaronr's Avatar
draaronr
Here
LR3
not 300tdi specific, but rover specific, the always tried and true AAA,
Old April 7th, 2010, 06:56 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I always pack a service kit to take along on a long trip. I would get an extra serpentine belt as they are not easily sources at you local repair shop. A u-joint and front bearings would also be nice. Extra clamps, duct tape, that cool self sealing tape, electrical connectors, etc.... Make sure you cool down the turbo after you stop if you have been running it hard. My 300 Tdi runs at 70 all day but it is with stock gears and a/s tires. It has been giving me about 26 mpg.
Land Rover 110
300tdi, tdi
300Tdi oil advice needed... Gkase Defender Technical Discussions 11 July 22nd, 2006 03:31 AM
Vibration location! Advice please.. EdF Defender Technical Discussions 11 January 1st, 2006 05:29 PM
Drive line problems HELP D90user Defender Technical Discussions 4 February 17th, 2005 10:19 PM
