3 link - Defender Source
Old August 6th, 2012, 02:11 PM
CDeWan
Clay DeWan
5.3L beastie
3 link
Any interest in a 3 link if I had some copies made up? Not sure of the cost yet - let's say $900? for a kit?
Old August 6th, 2012, 02:56 PM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
Clay - I am definitely interested. If this is anything like the brake light bar I can't go wrong. The only thing that might hold me back is the other changes I am going to have to make to the suspension to get this to work.
Old August 6th, 2012, 02:59 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
If someone could design a "universal" 3 link for V8s and Tdi's, I'd be interested.
Semper Fi!
Old August 6th, 2012, 03:10 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Tried that... you need to have a different x-member for each engine variant, other than that... rest is the same.
Old August 6th, 2012, 03:18 PM
CDeWan
Clay DeWan
5.3L beastie
crossmember
I have 2 crossmembers as copies, one goes over the Y pipe like the traditional crossmember and the other goes under the Y pipe. Both of the crossmembers are designed for a V8.
I am not versed enough to know if the placement of the crossmember on the frame is different in a tdi vs a V8...meaning if it is affixes more forward or aft of where the v8 mounts to on the frame.
Old August 6th, 2012, 03:41 PM
mongosd2's Avatar
mongosd2
Frank Rafka
01 D2 96 D1 83 110
tell me it's not that POS Safari Guard 3-link your copying
------ Follow up post added August 6th, 2012 03:49 PM ------
Not easy for a bolt on application...
Help with rear link removal UpnOver Defender Technical Discussions 19 October 22nd, 2009 05:21 PM
Need new drag link & pitman arm !? Rover- Girl Defender Technical Discussions 4 March 23rd, 2006 06:33 PM
Home design 3 link system UKlandyandy Defender Technical Discussions 65 February 17th, 2005 09:09 PM
Fusable Link by batt on 92 RRC...? RedRhinoProducts Defender Technical Discussions 5 February 6th, 2005 07:23 PM
