3.9 V8 in a series! - Defender Source
Old June 30th, 2006, 07:58 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
3.9 V8 in a series!
Does anybody know what it would take to put a 3.9 in a series assuming I have everything needed for the V8. I know I need grill, hood, engine mounts? what else?
World traveler
Old June 30th, 2006, 08:10 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Slam panel, radiator brackets, frame mounts for engine & transmission. Probably modify the bulkhead & gearbox tunnel and seatbox to clear the Auto trans & LT230....and some stronger shafts in the axles. Maybe some custom driveshafts...definitely some better brakes. You might have clearance issues with the series steering box/rods as well. I'd revert to your original plan and stick the series panelwork on the chassis you have.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old June 30th, 2006, 10:17 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
If you stay leafs here is an excellent option, http://www.seriestrek.com/parts.html
Jim makes up some pretty cool stuff, his personal series runs a Mercedes diesel, toyota e lockers and his own axles.
Old July 5th, 2006, 09:35 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
You don't have the change any body work if you don't want
http://www.eastcoastrover.com/Thompson109.html
http://www.eastcoastrover.com/Bulbulia.html
Mod the bulkhead, engine frame mounts stay the same, use an apdt to fit the Sereis gearbox, driveshafts stay the same. Use a RHD steering box with LHD guts installed and make a custom link from the box to the steering relay, custom exhaust, custom throttle linkage, etc. but no need to make all those other changes unless you want a more Defender look and depends if you want a 5 speed or an full time transfer case, bt to just install a V8 into a Series is no big deal.
Better brakes would be a good idea, as mentioned.
Email:
Old July 6th, 2006, 12:16 AM
Moses's Avatar
Moses
J. Moses
55 S1 86" RHD
Great info, Mike ! Thinking of doing the same thing in my S1 even though I shouldnt, but I'd rather enjoy driving it like my D1.
55 S1 86"
99 D1
If ya can't afford it, make it !
series, v8
3.9 V8, hp22 ZF trans., lt230 tcase (1.2), early Defender seats tommyd For Sale - Parts 9 February 11th, 2009 12:54 AM
Complete '89 Land Rover 3.9 V8 in CT BECFA For Sale - Parts 2 January 8th, 2009 10:28 AM
FS 3.9 V8 long block 40K miles ECR For Sale - Parts 1 May 30th, 2008 03:32 PM
Camshaft change 3.9 V8 95 D90 Neo Defender Technical Discussions 2 December 12th, 2003 02:29 AM
