2013 LR4 -set up for towing? - Page 2 - Defender Source
Old October 1st, 2013, 03:17 PM
Stickfigure
Lori
2013 LR4
here it part of the tow assist screen that is enabled after dealer install.
Old October 1st, 2013, 03:52 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
That's cool!!
Old October 1st, 2013, 09:33 PM
Interesting. Makes me wonder what if any negative effects there are for not getting this programming done.
Originally Posted by pendy
I'm here for the D's
Old October 1st, 2013, 09:35 PM
jafir's Avatar
jafir
Jafir Elkurd
I thought weight distributing hitches were a bad idea with air suspension.
Old October 1st, 2013, 09:44 PM
I've always assumed that it just changes the minimum distance for the park sensors. The trailer wiring will still work if the configuration file is not changed to "Tow bar fitted."
Old October 1st, 2013, 10:04 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Jimmy, when you program somebody's tow assist screen can you "add new" and call it "Mobile Meth Kitchen"?
That's be funny.
The whole Breaking Bad finale is on my mind lately...
Rent my
Old October 1st, 2013, 10:06 PM
Interesting. Whats the issue?
Old October 1st, 2013, 11:02 PM
That's be funny.
HAhah I might do that! Sometimes when I write state inspections on Evoques I write the vehicle type as "SUV" in quotations. Its not really an SUV.
Old October 1st, 2013, 11:10 PM
jafir's Avatar
jafir
Jafir Elkurd
The hitch can take weight off the rear axle (to distribute it to the front axle). When that happens, the height sensors will keep the ride height correct, but less air pressure is needed. If the weight shifts back to the rear for some reason, their won't be enough pressure and you might bottom out or something.... maybe loose control? I'm not exactly sure.
I don't know how big of an issue it is.
Old October 2nd, 2013, 07:49 AM
Stickfigure
Lori
2013 LR4
I thought that the computer update from LR dealer changes the way the air suspension works in tow mode as well ? ... wow, that's really an issue possibly.. need to investigate this.
Old October 2nd, 2013, 03:21 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Read somewhere that the stock hitch is not designed for weight load distribution and can break when "load" is pulling up on the hitch.
Not sure at what "weight"/"load" this becomes an issue.
Anyway, with all that fancy "I'll protect you at all cost" car electronics, I'm sure there is a slight chance of the electronic systems not protecting you when you have a trailer attached and in a weird situation ("CYA", "liability" words come to mind as I type this...).
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 2nd, 2013, 05:19 PM
Stickfigure
Lori
2013 LR4
I believe that is correct for the "stock" hitch, as per the owners manual...
lr4, wing
OME HD Springs & OME Nitrocharger Shock Set Steve Friedman For Sale - Parts 1 January 24th, 2008 10:11 PM
Set of 5 Q78 Super Swampers RedRhinoProducts For Sale - Parts 1 February 1st, 2006 06:43 PM
FOR SALE - Set of Used Oil Cooler hoses / window studs eric_besore For Sale - Parts 10 August 31st, 2005 02:18 AM
Why Dual shock set up? sflash868 Defender Technical Discussions 11 February 28th, 2005 02:34 AM
Mud tryres - Second set def-90 Defender Technical Discussions 3 May 10th, 2004 10:16 AM
