200TDI rear oil seals - Defender Source
Old April 14th, 2015, 09:27 AM
scrubs
henery
1974
Hi,where has ever one been finding a supplier for these?
Looking at a online manual,Russian one, it shows two part numbers for the rear crank seal
Old April 14th, 2015, 09:31 AM
BRAB
Brandon
200TDI in a RHD 1986 D90
Rovers north has genuine rear main seals in stock, just got one last week and installed it this weekend
Old April 14th, 2015, 09:32 AM
scrubs
henery
1974
Thanks for reply, was the plastic sleeve included?
Old April 14th, 2015, 09:35 AM
BRAB
Brandon
yep it is included as a protector and can be used to slide the seal over the crank, also use the old seal upside down to drive the new seal in to the flywheel housing
Old April 14th, 2015, 09:36 AM
scrubs
henery
1974
Thank you calling today
Don't suppose you have any suggestions that might of been left out of the video?
Old April 14th, 2015, 10:12 AM
Keep in mind you need to replace the flywheel housing to block gasket at the same time.
Old April 14th, 2015, 10:17 AM
scrubs
henery
1974
Yes that is getting ordered also.
have read that it's recommend to run some sealant around this paper gasket and to dry fit the oil ring gasket.
Are there any other tid bits that could help?
Old April 14th, 2015, 10:38 AM
I used black gasket maker on the paper gasket.
Also remember to clean all the grease out of the block threads for the bellhousing adapter bolts, make it as clean as possible, and use loctite on the bolts.
Old April 14th, 2015, 10:41 AM
scrubs
henery
1974
Ok thanks for that tid bit very much appreciated.
Don't suppose anyone knows where to order a genuine Land Rover seal from?
So far all I've found is britpart which I'll not use for this.
Old April 14th, 2015, 11:15 AM
Has the flywheel housing got the 4 bolts at the bottom that go all the way thru to the block?
Old April 14th, 2015, 11:18 AM
scrubs
henery
1974
I really don't remember.
------ Follow up post added April 14th, 2015 10:24 AM ------
Might be a bit to ask though going through don't suppose anyone knows the seal part #?
Looking to purchase on line and some are giving stock/inventory #'s
Old April 14th, 2015, 11:28 AM
Make sure that those bolts are there.
BRAB stated above that you can get the genuine seal from Rovers North.
I normally get my engine parts from Turner as it is no cheaper to buy from the US and you know they only sell good parts. For someone in the USA, using a USA vendor may make more sense.
200TDI engine parts from Turner Engineering, pistons, bearings etc
Note Turner's statement: "Rear oil seal. Dowty original equipment superior to current oem seal"
I "think" this is the genuine seal at RN, but maybe Zach can clarify. They need work on the details of their descriptions... OIL SEAL REAR 5 MAIN BRG, RNL348, ERR2532 - Rovers North - Classic Land Rover Parts
Old April 14th, 2015, 11:30 AM
scrubs
henery
1974
Thanks,RN over 10 days out,will try Turner's out
200tdi, seals, tdi
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
200tdi injection pump (needs seals or rebuild) tomaco1 For Sale - Parts 4 August 27th, 2012 08:01 AM
300tdi crank and cam oil seals Shearpin Defender Technical Discussions 6 May 25th, 2011 09:45 AM
TD5 bulkhead vent seals vs. NAS seals Tyler Wirken Defender Technical Discussions 11 March 14th, 2011 10:22 PM
OIL...oil...oil... norros Defender Technical Discussions 20 August 22nd, 2004 01:30 AM
