2008 L322 Trans Failure.. - Defender Source
Old July 8th, 2017, 09:57 PM
ron's Avatar
ron
Ron
1995 110 Beach Runner
Smile 2008 L322 Trans Failure..
driving at 65 mph and trans stopped working... pulled to side of road put truck in park and it rolled backwards... there is no park.....
was told by Land rover tech that output shaft from trans stripped flange to transfer case....
anyone heard of this...
Have a fix ..
have a trans????
have a transfer Case?????
thanks.....
good luck with your search
Old July 8th, 2017, 10:08 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Yes, heard of this a few times. Have a buddy that owns an indie shop and he sees this happening.
Old July 8th, 2017, 10:46 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
These were just on sale for 1560 I believe, a bit more now.
I was looking at resealing my tcase and after seeing what the re-seal bill was I thought maybe just go this route: 2005 -2009 LR3 Transfer Case 4.4L V8 (Professionally Rebuilt)
Old July 8th, 2017, 11:30 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Make sure you use the special grease on the splines, I have a tube here somewhere
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old July 9th, 2017, 04:41 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
You are sure not talking about this failure between LT77 and LT230
Actually we are talking about this one?
Old July 9th, 2017, 05:04 PM
ron's Avatar
ron
Ron
no 2008 Range Rover HSE
is that what you have pictured?
is the shaft removable without taking the trans apart?
thanks
Old July 9th, 2017, 05:42 PM
Arlo's Avatar
Arlo
Kurt Ohlendorf
1997/130CC
I'm sorry, the pictures are showing the intermediate shaft between Ford transmision and LR transfer gearbox. It's common inside the TD4 (Puma) engine generation inside every Defender. And it fails like yours.
To replace the shaft some very special tools are necessary!
And the transfer case plus the added case keeping the shaft, have to be removed too.
Old July 9th, 2017, 07:05 PM
Ron: Bunch of Transfer cases and transmissions on Car-Part.com--Used Auto Parts Market
Old July 9th, 2017, 09:48 PM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Man, this sucks - I'm still trying to get around to buying one of the SC'd L322's - is there a pre-emptive surgery that would prevent this?
And is pulling a medium-sized Airstream gonna make me 10x more likely to fall victim?
Old July 14th, 2017, 10:04 AM
ron's Avatar
ron
Ron
anyone have a transmission for sale
Old July 14th, 2017, 11:49 AM
phoenix37's Avatar
phoenix37
john
car-part.com
2007
Transmission Assembly
LandRover Range Rover 89K, 1 YEAR PART WARRANTY 89,000 A L01066 $1999.48 Nationwide Auto Recycling USA-MA(Lancaster) Request_Quote 1-866-534-0477 Request_Insurance_Quote
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Rear trailing arm bushing failure sheki Defender Technical Discussions 23 July 5th, 2006 09:20 PM
Replacement Motor and Trans for 110 gearco Defender Technical Discussions 39 July 2nd, 2004 02:16 AM
Check your trans filter! {manual} Bowtracer Defender Technical Discussions 5 May 25th, 2004 10:32 AM
ZF trans temp? dmarchand Defender Technical Discussions 2 May 17th, 2004 10:45 AM
