2 questions - Defender Source
Old October 11th, 2006, 06:06 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
2 questions
my first question is how loud is a flowmaster 40 series at highway speeds? And my second one is their is a clicking sound coming from the front of the engine near the belts what could this be? any help would great because my muffler is shot and has a hole in it and that sound is annoying me at idle
2002 dodge 2500 CTD-blows some smoke
1997 LR D-90 ST
Old October 11th, 2006, 09:09 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Funny, I have a clicking sound too. Same place. Only on cold mornings. Stops when it gets to normal operating temp. I hunted around with and engine stethoscope one morning, couldn't narrow it down. Hasn't been cold enough to recreate it. I read something about the oil pick-up when it's cold. I have an oil pan heater that I am going to use the next time it gets cold. Supposed to drop to 30 in the next few days so I should be able to investigate more. I have the 3.9L by the way.
Oh, do a search for "ticking noise". You'll find that oil pick up thing I mentioned.
Old October 11th, 2006, 09:47 PM
kjh888's Avatar
kjh888
Kurt Harvey
97 Defender 90 ST
at highway speeds the 40 series is not bad at all, with my stock muffler i still had to crank my radio up because the wind noise is so loud
Old October 11th, 2006, 11:00 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
The ticking sound is most likely a leak in your exaust manifold. When your motor heats up the headers expand and the sound goes away. It is not a big deal other than it is annoying and robs a little power and gas milage.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 11th, 2006, 11:05 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
i have the sound when the engines cold or hot
1997 LR D-90 ST
Old October 11th, 2006, 11:13 PM
a ticking sound when cold or hot means that your exhaust manifold leak is big enough that the heated metal expansion won't close the gap. step 1: tighten down your manifold bolts. if that doesn't do it, you probably had a piece of the manifold gasket blow out...fun, fun, fun. good luck.
Old October 12th, 2006, 01:40 AM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
This happened on my 90 as well. Started to lose power up hills. If you lucky than its just the manifold down pipe gaskets. I actually had cracks around the weld bead on the Y pipe. I just ground them down and rewelded them but if it happens again I'll probably just wind up buying a new pipe.
Neil
Old October 12th, 2006, 08:25 AM
the 40 was to loud for me, resonated bad inside. I have a magnaflow now that I really am happy with. Its a little more compact than the 40 series and its stainless steel
is it a bitch to replace the manifold gaskets? How likely is it that I will break a bolt off in the block?
Old October 12th, 2006, 12:55 PM
Neil McCauley
Neil McCauley
Well I live in California, but the previous owner lived near the beach and most bolts were covered in surface rust. It all came apart easy anyway. Squirt some penetrating oil on it a couple times throughout the day before you trying to take it apart. You'll need something like a 13 or 14mm socket with really LONG 3/8 extensions. There will be 3 studs/nuts per side, 2 nuts to undo at the muffer. It comes apart real easy at the muffler, just one metal donut that is reusable. (I re-used it, no problems yet) You don't have to but it would be nice to use new nuts and a torque wrench.
Neil
Old October 12th, 2006, 05:41 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
For me...exhaust manifold bolts break like glass.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old October 12th, 2006, 05:55 PM
Exhaust manifold is the one pressing against both sides of the engine block sides, not by the muffler, and they SUCK to replace. And they have locking flanges with tabs that are bent onto the nut surface to keep bolts from loosening, that have to be bent back out to release the bolt. And the fuel lines are quite annoying and in the way.
Old October 12th, 2006, 06:44 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
it was a spark plug that wasn't screwed in all the way, and my whole exhaust system from the manifold back is pretty much gone. So i guess it's time for some highflow cats and a 40 series off-road muffler
1997 LR D-90 ST
Old October 12th, 2006, 07:52 PM
Neil McCauley
Neil McCauley
Alot easier to replace with the motor out of the bay. Just leave the Y-pipe connected to the rest of the system. Since you've went that far, might as well fit a new motor.
3-Link Suspension Setup questions chrisvonc Defender Technical Discussions 20 July 18th, 2006 10:37 PM
LT230T Front Output Flange questions...... kiphartzell Defender Technical Discussions 20 March 2nd, 2006 08:17 AM
Dumb questions to ask when looking at a defender... Grouchie@irdumb.co Defender Technical Discussions 2 July 6th, 2005 11:31 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
New differential questions... wicks Defender Technical Discussions 15 May 5th, 2004 11:39 PM
