2" Lift, how big of tires can I get? - Defender Source
Old November 20th, 2008, 11:19 AM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
I am thinking about putting a 2" lift on my d90. The lift would be a true lift, not just spacers.
I was wandering if someone could tell me how big of tires I could get under it with 2" and no trimming? I was thinking 33's or 34's, but I really don't know what will fit.
thanks everyone!
Old November 20th, 2008, 04:03 PM
I run 33" fine with a 2" lift (although they might be closer to 32" actual)
Old November 20th, 2008, 04:05 PM
outfield
Steve
1995 D-90 SW #351
285-75-16's fit great, they measure about 33 inches. You can put these on stock or aftermarket wheels.
Old November 21st, 2008, 07:12 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I thought 265 was the limit for 7" rims.
- Charles Eames
Old November 21st, 2008, 11:25 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
A quick search will yield pages upon pages of threads answering the same question.
Old November 21st, 2008, 12:12 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
As someone else mentioned, 285's are wider than the tire manufacturer recommends for the stock 7" wide wheel. Keep in mind that a 285/75-16 will fit on a stock D-90. The bigger problem is that no matter how much lift you install, running a 285/75 on the stock wheels will lead to rubbing because of the width of the tire. They will rub the front shock towers, radius arms, and rear inner wheel wells, unless you run a wheel spacer, or different offset wheel.
As with any suspension lift, keep in mind that unless you limit compression travel with extended bump stops, you don't really gain any ultimate tire clearance...
~Scott T.
'95 D-90 ST - AA Yellow
Old November 21st, 2008, 12:44 PM
TravelerBT's Avatar
TravelerBT
Philip Marshall
none - :*(
How do the wheel spacers work? I am just curious... sorry for the question... I am new to all this stuff. does anyone have any pictures of before spacers were put on a d90 and after they were installed?
So it sounds to me like if you want to do the wider tires, you need to get wheels that will take the wider tire.
tire, tires
So do you think the tires and lift are big enough on this Disco? pmd Misc. Chit-Chat 8 February 25th, 2009 04:49 PM
2" OME Lift Before/After Pics pcscharfe Defender Technical Discussions 5 November 13th, 2007 02:09 PM
Question about 2" lift on NAS D110 Stmpede Defender Technical Discussions 10 April 3rd, 2007 06:12 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Tires, Tires, Tires Joe P Misc. Chit-Chat 28 August 9th, 2005 09:58 PM
